Hey guys. Just bought some 2005 OEM revised OEM Z springs and I wanted to make sure they are the revised ones. The rears have 2 red dots along with a single purple dot. The fronts have a pink dot on them. Are these the revised ones with the higher spring rates? TIA
Jason
Jason
That is also what I got on ’05 OEM Z springs.
On my350z.com forum someone (I think it was Gsedan35) posted:
The rear springs can be traced via a dial caliper, measure .57" and your holding a 04.5 rear springs, measure less and it's a 03/04 rear spring. Front springs did not change …
And
03 springs, have two red dot's with one white dot stamped on the springs.
04.5+ rear spring have a mauve colored dot (call it a pail purple, I dunno).
And
2 red
1 purple
These are def '05 350Z..
I know the car they came off of..
1 purple
Quote:
1 purple
cool. I'm sure they were but I wanted to make sure b4 I pay someone to put 'em on. Thanks for the replies.Originally Posted by inTgr8r
2 red1 purple
Jason
Quote:
I'll let you know next week. I just bought an 05 sport tuned suspension setup for my 03 5AT Coupe and it's on it's way. When it gets here I'll post up the info if no one else has in the meantime.Originally Posted by GGGGGGGG
Does the same color code apply to '05 coupe sport springs as well?
i can almost see someone getting ideas of painting their factory springs
with generic paint and selling them for something else.
becareful out there.
And
Originally Posted by dovla
That is also what I got on ’05 OEM Z springs.On my350z.com forum someone (I think it was Gsedan35) posted:
And
Are these from an '04 with UNREVISED springs or did the guy who sold me these lie to me just to make a buck?! I specifically told him what I needed and he assured me that they were off his '04 and were the unrevised version.
Looking at the springs I was sent.... the smaller coils have one PINK or SALMON colored dot with a visible part number M3X01874 and the larger coils have 2 red dots and one white (yes white) with no visible part number.
I just put some oem 4.5 350z springs on my car. I know for a fact that my fronts are lower. But my rear barely dropped or didn't even drop at all. I took a look at the rear springs they replaced and i noticed two red dots and a purple dot. Isn't that the oem 350z springs? What is the color code for the oem 4.5 g35 coupe rear springs? I'm thinkin that the guy didn't even replace my rear springs. What is the color code for the front springs and rear springs of the oem 4.5 g35 coupe? Thanks in advance.
