Tein Coilover rear noise?
Old Nov 9, 2005 | 02:13 AM
G35COUPEBC's Avatar
Hello,
Over a month ago I had the Tein CS coilovers installed on my 04 6MT coupe, everything in terms of comfort and handling is just what I anticipated.
I posted a little why back a question about a noise; in particular a rattle type sound in the rear when going over bumps or driving on slighty uneven surfaces. A few replies mentioned this was normal w/coilovers and no solution or details to backup.
After asking around some more (installers & shop that sold me the coilovers), I've been told the noise has to do with the pillow mounts and is normal for a coilover system, can anyone confirm this? My installer said coilovers are designed for track with smooth surfaces, street driving = noise.
They advertise this system as "TEIN adapted a hard rubber upper mount for noise proofing and mono-tube type shell case to heighten road holding." Before I purchased/installed this system I was under the impression quite ride....I find this misleading.
Is it really the pillow mounts or am I being mislead? Any help would be appreciated.
Thanks!
Old Nov 9, 2005 | 01:07 PM
roneski's Avatar
Devil's Advocate
I just installed the Flex and had a similar noise. My problem was that the metal seat at the top of the rear shock (visible from the wheel well when installed) was loose. There is a nut above it that needed to be tightened. Problem is that you have to pull the shock to get to the nut. Not a big deal, but kind of a PITA.
I'd bet that you are having the same problem.
Old Feb 26, 2009 | 10:57 PM
Matthew121's Avatar
sorry to bump a old thread, but I have this issue and im not sure what nut you are talking about...
Old Feb 27, 2009 | 01:05 AM
G35Papa's Avatar
When you take the rear shock out, you will see a nut right in the middle, on top, where the damper adjustment **** is.
Old Feb 27, 2009 | 02:14 AM
Matthew121's Avatar
oh that nut, lol. alright.
and I have been reading around it I guess it is more common for people to have coils that are completely quite. I will try this, but I guess Im just more concerned that it is nothing too harmful or irregular.
rezendvous420
May 31, 2020 01:26 PM
ScraggleRock
Aug 11, 2015 10:16 PM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
