? for Tein CS users
Old Nov 11, 2005 | 02:33 PM
Beta99's Avatar
? for Tein CS users
My current setup is the stock 05 6mt coupe sport suspension.
I want to lower the car (~1” front and ~.5" rear) with only a slight increase in stiffness...To those who have the Tein CS installed, what is your daily/spirited driving setup?
What about that rear noise, is everyone else having it too?
Old Nov 11, 2005 | 03:13 PM
G35COUPEBC's Avatar
I've had the Tein CS installed on my 04 6MT w/stock 18's for about 7 weeks now. I'm quite happy with comfort and use for daily driving.
I pretty much had it set to the reference figures (F:1.1/R:0.75), I think the appearance looks great, especially with stock wheels for now. I have the rebound/dampening set approx. in the middle and the ride is only slightly stiffer than stock. If your looking to make it exactly like a stock ride, I think it's possible if you play with the settings even more.
After the alignment sources tell me I'm ok to without a camber kit etc, however I'll see how my tires do after more driving.
Now the only issue is the rear noise, it seems to make alot more noise compared to when I 1st had it installed. It use to only make a slight rattle noises, now I'm hearing squeeks in the rear too, however this maybe because the weather is colder now? Keep in mind this is only when driving over uneven surfaces or speed bumps. I've been told w/coilovers always expect to hear noises, it's part of the setbacks for this setup.
Hope this helps...
Old Nov 11, 2005 | 11:24 PM
Cactus's Avatar
Sounds like your alignment sources might be wrong. I thought anything over .5 inches screwed the camber???
Old Nov 12, 2005 | 02:55 PM
G35COUPEBC's Avatar
Alignment is not within factory specs, however within a reasonable variance to go without the kits/arms etc.
Old Nov 14, 2005 | 12:22 AM
Beta99's Avatar
Thanks for ur input G35COUPEBC...anyone esle wanna chime in?
Old Nov 14, 2005 | 12:43 AM
caelric's Avatar
Between TEIN CS and TEIN Flex, which one is the one closer to stock? I thought the Flex was harder, and the CS closer to stock, but I can't remember correctly now...
Dave
Old Nov 14, 2005 | 12:56 AM
Gsedan35's Avatar
Dave
Most certainly the CS.
Old Nov 14, 2005 | 12:57 AM
caelric's Avatar
Ok, thanks
Dave
Old Nov 14, 2005 | 01:04 AM
GEE PASTA's Avatar
Florida G35 Club
Here is a little info for you. You will need to apply some silicon spray or W-D40 to all the suspicion joints. I had problems with my sways making noise. IM real happy with the CS
http://my350z.com/forum/showthread.php?t=138167
Old Nov 14, 2005 | 10:07 AM
Beta99's Avatar
Thanks GEE PASTA but was that a typo??
50/50 Frt. 25/75 back...
Old Nov 14, 2005 | 12:35 PM
GEE PASTA's Avatar
Florida G35 Club
Front setting on the coil overs were 8 clicks out from the softest setting, The backs were 4 clicks out from the softest setting.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
Blue Dream
Dec 5, 2015 10:56 AM
w4kj4k
Oct 2, 2015 07:57 PM
