Newbie,Car feels floaty, help!
Old Nov 25, 2005 | 09:53 PM
chaos's Avatar
Just got my car back from the shop with 350Z Tein S-techs, Hotch. sways installed and a twin turbo kit . My problem is the car feels floaty when i hit a bump at high speeds, the car doesn't really feel tight on turns. When you turn the steering wheel, it takes a little while for the car to start the turn it takes a sudden dip, not a big dip but sudden, into the turn almost forcing me to compensate. My rims are 20's and the sways are set to stiff front and rear I don't go to the track but my driving style is spirited to say the least. i'm new to suspension and stuff, been more interested in HP and TQ, now that i got that what suspension set up should i use. It sounds like the Tein coilovers are good or should i stick with S-techs and do something else. I know i might have to change the sway setting but to what? All help is appreciated.
Old Nov 25, 2005 | 09:56 PM
chaos's Avatar
Hehe! Sorry i have an 04 6MT G35c
Old Nov 25, 2005 | 10:59 PM
godmans's Avatar
I am no suspension expert, but wanna try adjusting the sways to start with?
since most people would try a soft / medium or soft/stiff ..to compensate for the natural tendency of the car to understeer
hope this helps,
Godmans
Old Nov 26, 2005 | 01:04 AM
kenchan's Avatar
you need to swap out the dampers. try some D-Specs.
Old Nov 26, 2005 | 11:37 AM
chaos's Avatar
Sorry, but what are D-Specs.
Old Nov 26, 2005 | 11:39 AM
chaos's Avatar
Thumbs up
hope this helps,
Godmans
Definitely going to try changing the sway settings, thanx
Old Nov 26, 2005 | 12:04 PM
kenchan's Avatar
chaos-check this out:
http://www.tokicogasshocks.com/car/d-spec.html
Old Nov 26, 2005 | 01:01 PM
Teeter's Avatar
+1. You definitely need dampers that can keep up with your firmer springs. I recently put 350z H-Techs on my '05 Sedan and adding D-Specs made a huge difference. -T
Old Nov 26, 2005 | 01:04 PM
chaos's Avatar
Thanx ken, very helpful. Would you get the ones for the Z or G. This seems cheaper than coilovers will they work as well, and what else will i have to change or adjust ( camber, toe,...)
Old Nov 26, 2005 | 03:48 PM
kenchan's Avatar
chaos- no prob. i would get the DSP-7's the ones for the G.
(well, that's wat i use right now. )
Old Nov 26, 2005 | 05:11 PM
Teeter's Avatar
FWIW, I'm also using the DSP-7's. Since they're fully adjustable, I don't see any reason not to get the "G" version.
-T
Old Nov 26, 2005 | 05:59 PM
kenchan's Avatar
right. if you're running 350z springs, then it might be better to use the DSP-9's because the springs are shorter... minimize the chance of spring rattle at
full extension.
but if running springs made for the G, just use the DSP-7's.
Old Nov 26, 2005 | 06:26 PM
chaos's Avatar
full extension.
Yeah, i think i'm going to try the ones for the Z. See how it goes, are those fully adjustable too.
Old Nov 26, 2005 | 07:52 PM
kenchan's Avatar
yep, they're adjustable like the DSP-7's (firmness adjustable, no height adjustment).
Old Nov 27, 2005 | 03:26 PM
chaos's Avatar
Hey, are coilovers height adjustable?
