Sway Bar Bushing Lube
Old Dec 25, 2005 | 05:57 PM
OCG35's Avatar
Does anyone know a retailer that sells Energy Suspensions "Formula 5 Pre Lube"?... I can find it online but the shipping costs more than the grease
It's hard for me to justify $8 to ship $6 worth of product. Haven’t found any auto parts stores that have it.
Any help is appreciated
Old Dec 25, 2005 | 06:12 PM
cyphr's Avatar
You might want to look at heavy duty marine grease. That should work as well or better than the white lithium grease you're looking for.
Old Dec 25, 2005 | 06:25 PM
OCG35's Avatar
Thanks for the suggestion/advice... I've heard (and read) real good things about the Formula 5 lube... Justin at everythingG35 has had similar problems I'm having with sway bushing squeaks and said this is the only stuff he found that works (it has stayed noise free for several years). After Google searching I read pretty good things... If I can find it at a local store I'd like to give it a try.
If I can’t find it I'll consider your suggestion.
Thanks again
Oh BTW... Merry Christmas everyone
Old Dec 25, 2005 | 07:22 PM
GEE PASTA's Avatar
Florida G35 Club
Just a quick note. Remove all the paint under the sway bushing. Its worked great for me, just using white grease.
Old Dec 25, 2005 | 08:28 PM
wanalaugh74's Avatar
Wil you still have this problem if you change out your bushings all together?
Old Dec 25, 2005 | 09:06 PM
kenchan's Avatar
I use white lithium grease available in a tube.
great stuff, available at your local autoparts store.... it think even
walmart has them.
Old Dec 25, 2005 | 10:03 PM
SLVRG35's Avatar
If you have an Autozone where you live, they carry it.
Old Dec 26, 2005 | 12:47 PM
OCG35's Avatar
I tired - the one near me has it in the suspension kits they sell, but not sold separately... The guy said he would consider piecing some out for me if I can’t find it.
I'll try another AutoZone and see if I can find.
Thanks, everyone, for the responses.
Old Mar 17, 2011 | 04:13 PM
od2681's Avatar
This might be a dumb question, but do I have to remove the sway bar or any components in order to apply lube?
Old Mar 18, 2011 | 10:52 AM
05Scoobyroo's Avatar
Yes, you will need to remove the bushings and brackets holding each bushing. Im actually servicing my bushings tomorrow morning with the formula 5.
Old Mar 18, 2011 | 11:29 AM
od2681's Avatar
crap I was hoping to just spray the crap out of it.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
NyCrAzY
Oct 1, 2015 09:19 AM
