Best Suspension for Coupe
Old Jan 16, 2006 | 05:18 PM
e420x's Avatar
Mod Junky!
What would be the most comfortable, least bumpy setup for an 06 coupe?
Would eibach or H&R springs be just as good as the basic Tein Setup? Will coilovers be a better ride? I dont care about dropping it low as I prefer a 1 + drop and dont need the adjustability of coilovers.Its all about the ride quality
Old Jan 16, 2006 | 05:59 PM
e420x's Avatar
Mod Junky!
I have had H&R springs on my VW and H&R Cup Kit on my BMW, they both ride nice...but I am willing to spend more $$ for a better ride so I want to know what will ride best.
Old Jan 16, 2006 | 06:22 PM
CreativeAutoworks's Avatar
H&R and tokico d specs, but if comfort is a big factor make sure to get a set of dampering adjustable shocks
Old Jan 16, 2006 | 06:27 PM
kenchan's Avatar
if comfort is a big factor, you need to keep your nominal spring rates
around 325-350 range, then get d-specs.
Old Jan 16, 2006 | 07:13 PM
haze's Avatar
keep in mind if you get springs only without shocks, ur stock shocks will wear out much faster due to the increased compression and stress.
Old Jan 16, 2006 | 07:40 PM
vat_U_tink's Avatar
I have the KW Coilovers V3 on my 05 Coupe. VERY VERY happy with them. There german coilovers. Mostly used on porches. I highly recommend them but a bit more money then the competition...
Old Jan 16, 2006 | 09:32 PM
e420x's Avatar
Mod Junky!
Which H&R, just springs or a kit? What are some damper adjusting shocks?
Old Jan 16, 2006 | 09:47 PM
Disco_Monkey's Avatar
I Eibach Pro-Kits with Tokico D-Specs. Pretty comfortable and only dropped 1".
35 series tires make it a little harsh on bumpy roads.
Old Jan 16, 2006 | 10:04 PM
636Racer's Avatar
I'd go with Swift Springs and Koni shock/strut.
haze's Avatar
As far as I know, the H&R only makes 1 type of springs for the g35 coupe, and that is the Sport springs. I just got those install on my coupe with nothing done to the stock shocks.
https://g35driver.com/forums/brakes-suspension/81853-coupe-lowered-h-r-springs-pix-alignment-results-suggestions.html
I think the D-specs has dampening adjustibility.
Old Jan 17, 2006 | 12:37 AM
kenchan's Avatar
keep us posted on durability. there's been several cases of those blowing
within several thousand miles on different cars (bimmers, cooper-s).
the seals they use are not good, from what i hear. they look great
though with that stainless shell and purple seats. that would be my
choice for my cooper-s.
Old Jan 17, 2006 | 10:07 AM
e420x's Avatar
Mod Junky!
I am considering putting Tokico D- Specs and 350Z H-Tech Springs on my 06 MT. The car has nice stock 19's so I figured it would look better with a little drop. I am wondering will their be a big improvement over stock suspension with this setup? I know I will get a little bit of a drop which i want for looks but is it worth it for performance?
Old Jan 27, 2006 | 08:48 PM
zpeedray's Avatar
I install D-Specs full stiffness and H&R springs and the car is to low about 1.8about 3" from the ground with stock bumper and no lip.
Rigth now im searching this and all threads about springs because Im going to change it.
Old Jan 27, 2006 | 11:49 PM
G35zkyline's Avatar
the big diference will be that your 06 springs have almost double the spring rate from the H tech springs you are about to put in your car wich will only contribute to the understeer our cars have. my advise to you is if all you want to do is lower the center of gravity on your car, go with the 350z stock springs (05 or later) or the Espelir GT wich are stiffer.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
jjohns2711
Aug 5, 2015 08:58 AM
kinetek
Aug 3, 2015 04:25 PM
CJay
Aug 1, 2015 03:57 AM
Carlos_G358696
Jul 18, 2015 03:22 PM
