camber issues fix???
Old Jan 17, 2006 | 08:44 PM
MI SO FST's Avatar
I was wondering, I have lower my 03 G35 sedan with 04.5 350Z suspension. Now I have rear camber. Since I am using the stock parts from a 350Z and they have no camber issues cause its comes stock on the car and it should be set to perfect spec. What if I use all the arms from the 350Z. will that help out my camber at all? I am guessing but not sure, that the 350Z has either longer or shorter arms to keep the camber straight. Please correct me if I am wrong and explain to me what the differents is. Pic of anything kind of differents would be great.
Old Jan 30, 2006 | 12:32 PM
IAPDirect.com's Avatar
I am not sure about your question but I would think it would be cheaper and easier to install aftermarket rear camber kits. Please correct me if I am wrong. Check out www.camberkit.com for the rear SPC camber/toe kit. PM me if you have any questions.
Hope this helps.
Old Jan 30, 2006 | 01:27 PM
MI SO FST's Avatar
Hope this helps.
Yea but i dont want to do any camber kits. I dont plan on going lower then the 350Z suspension. I just wonder and any of the 350Z's rear arms are longer or shorter then G35's
Old Jan 31, 2006 | 01:22 PM
Gotcha. Is it because you feel it will be more of a hassle? In the case of the kit, the alignment is still a standard alignment (you will just have more adjustment than a stock Z). Just some info.
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
