The Usual Rim and Suspension Questions
Old Jan 31, 2006 | 10:48 PM
Nickk6's Avatar
So my tires are bald after a little over 18k of use. Damn! I decided if I need new tires, I need new rims.
I am looking for 19" rims. For those people who run 19" I am wondering what size tire you are running and how the rims are holding up. I drive on some rough roads on a regular basis and if I am going to buy some nice rims, I want to make sure the tires can protect them. I know the obvious, but hopefully those with experience can provide me with some real life results.
Right now I am debating between 245/45/19 all around or 245/40 f and 275/35/ r.
I plan to lower the car with Tokico d-specs and a spring that will only drop an inch. What width rim should I go for and what offset?
Old Feb 1, 2006 | 01:32 AM
skeleton_cru's Avatar
Sedan
I have had 19's on my sedan for nearly a year. I went with 19x8.5/+38mm on all four corners and 245/40 tires. The 245/40 tires were the closest I could get to the stock tire height because I wanted minimum speedo error. I have driven over some pretty bad roads and hit a few potholes. I even ran over a big, heavy metal object that caused a huge bubble to form on one of my tires. Through all that my wheels have not been damaged. I keep a close eye on my tire presure to help protect my wheels and I am very carfeful when I drive over railroad tracks, etc.
Old Feb 1, 2006 | 12:58 PM
jimmyc13's Avatar
CRU - Are your rims cast or forged?
Nick - I haven't heard of anyone running 245/45/19's.....not sure if those'll fit. The most common sizes I've seen/heard of on this forum are 245/40/19's if running non-staggered w/out a drop, 245/35/19's if running non-staggered with a drop, and if staggered, 245/35/19 F, 275/30/19 rear. Just my $0.02.
Old Feb 1, 2006 | 01:53 PM
perry05G35's Avatar
I am running 245/40/19 all around with out any problems and the roads here in Hawaii are pretty bad. You can go with a 40 series and still get a 1 inch drop I have eibachs with no rubbing issues.
Old Feb 1, 2006 | 03:47 PM
codeflux's Avatar
VOLK LE37T gunmetal with chrome lip
front: 19x8.5 +43
rear: 19x9.5 +43
Michelin Pilot Sport 245/35-19 & 275/30-19
no rubbing whatsoever.
Old Feb 1, 2006 | 03:55 PM
Endless G's Avatar
Not to Jack the thread, but who else here has the Eibach and D-spec combo!?!?
Old Feb 1, 2006 | 05:27 PM
shodog's Avatar
I run a 19" with 275-30 rears and 245-35 fronts. Offset is 35mm and I had to roll the rear fenders. The wheels are ruff 277 and they are not all that expensive. I was going to go with J-lines but was worried about strength. My ruff's are cast and a bit heavier but they had held up to all kinds of road imperfections. The only thing the can't hold up to is the ball hitch on the back of a suburban which my wife nailed or the curb by my sons school which i nailed.
Old Feb 2, 2006 | 07:36 AM
Sedan
Cast.
Old Feb 2, 2006 | 07:37 AM
Sedan
I should have added that I'm dropped about 1.5" on HKS coilovers, no rubbing issues.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
DimQ
Aug 14, 2015 02:04 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
