G35 Front Strut Tower brace
Old Jun 14, 2006 | 02:24 PM
  #166
Disco_Monkey's Avatar
How much for a black one shipped to CA 94610? Or should I just wait until I get my JWT TT done?
How do you guys feel about those GT SPEC lower bars?
Old Jun 14, 2006 | 03:33 PM
  #167
InTgr8r's Avatar
Staff ALUMNI (retired)
You need to e-mail Scott for shipped price wa2good@hotmail.com
JMO, but I don't see how a support that runs beside (parallel to) an existing support stucture can add any meaningful benefit.
Old Jun 14, 2006 | 03:42 PM
  #168
I emailed him.
I read mixed reviews about the lower bars and I personally couldn't see how they would make a noticeable improvement. Just wanted to see what others thought about those.
Old Jun 14, 2006 | 03:54 PM
  #169
SixFive's Avatar
The GT spec bars make a tremendous difference. There are 3 bars I use together, that make a big difference in tortional rigidity at the expense of some hoppiniess in fast hard turns over uneven surfaces. The steering has a different feel to it and is much more responsive. Not sure about "parallel to existing structures." There is nothing that appears to be parallel already there. For the price of the upper strut bar, I wonder how the performance compares in context of price for the single lower front strut bar...
Old Jun 14, 2006 | 04:08 PM
  #170
InTgr8r's Avatar
If you've tried them & like them that's great.
For parallel..see pic..... .
JMO but with the support already there, I don't see what is the bar adding?
Less flange flex?? ....ummmm maybe
Old Jun 15, 2006 | 12:50 PM
  #171
Ordered my VRT Brace.
I'm going to pass on those GT Spec Bars though.
Old Jun 15, 2006 | 01:36 PM
  #172
SixFive's Avatar
I see your point on the potential redundnacy. There has been no review by anyone, I am aware of, that focuses on one bar at a time. I don't see the front bar as the oil pan covers keeps the view impeded. While the thing may not be that great it was 89 bucks or something as opposed to 400-500 bucks. Where this car needs buttoned down IMO, is rear end. Even reviews of the 03 back a few years mentioned how hoppy and uncontrolled and slide happy the rear end gets over uneven surfaces in turns. The combination of a sway bar and the lateral lower GT spec bar PLUS the lower strut bar keep things better controlled IMO.
Back to the front... I will say after having all 3 bars installed, my turn in is noticeably faster and the response is terrific. The steering wheel tells much more of a road condition story and the car seems to be much more rigid over all surfaces and frame flexing situations. The uppers strut seems to be not only expensive but take a day for the install. I'd be on it if I had my own garage or a race car. For daily driving, I think I'll stop here.
Old Jun 26, 2006 | 03:18 PM
  #173
wa2good's Avatar
Still available, e-mail me at; wa2good@hotmail.com
I like this pic of the STB on Eagle1's car in Sport Compact Car Magazine.....
Old Jun 27, 2006 | 10:15 PM
  #174
rcdash's Avatar
hmmm, i was going to attempt this, but didn't realize the install was that difficult... are the instructions posted somewhere?
i've done all the work in my car so far, but it's been mostly electronics (car pc, amps, speakers, etc) and minimal mechanical stuff (isothermal spacer, k&n, 10 wire ground kit, stillen sways).
Is special equipment required (like something to get springs on and off)?
Again, if instructions online somewhere, I can just read it and decide if I can handle it or wait for my build to get it done...
Old Jun 28, 2006 | 03:56 AM
  #175
wa2good's Avatar
I am currently working on having the STB added to our website (with instructions) Due to the tight and limited under-hood room on these cars, these STB's can be a little tricky to install, but most I have seen and done took about 20-40 minutes with only a few hand tools, a jack, and jack stands. But (so far) all who have installed this brace are more than happy they did.
If you want to...PM me your e-mail and I will e-mail you back with the instructions for you to review yourself.
Old Jun 28, 2006 | 05:43 PM
  #176
Woh, you weren't kidding. That's a whole lot of cutting but looks fairly easy, it just seems time consuming. Well worth it though from the pic.
Old Jul 4, 2006 | 08:07 AM
  #177
InTgr8r's Avatar
Thumbs up Installed on a sedan
This one definitely took a little finesse to get it installed.
I ended installing a Stillen CAI; the OEM airbox was just too much of a pain to try to work around.
For those interested, I'll post more install info in a separate thread & link it from here.
This bar is everything others have said & more.
I could not believe the difference this made in the car.
Like someone else said b4, I could feel the difference just backing out of the driveway.
Just driving down the road & hitting irregularities or dip in the pavement....
you can actually feel the suspension working without jarring & twisting the car.
& steering.. it's like comparing a scalpel to a machete.
Don't get me wrong, it's still no sports car... but WOW.
Thanks Scott for a great product.
:NOTE:
305Z cover to be fitted later
:EDIT:
LINK to some DIY install notes
Old Jul 4, 2006 | 10:28 AM
  #178
Zat_Zuma's Avatar
Good job!
It's amazing the difference the strut bar makes. Did a Solo event with the bar installed and the difference was noticable.
Your right, it's not a easy install ...... it's a tight fit.
Does your hood make contact with the bar? Mine touches a bit and I removed the heat or sound proofing on the hood for more clearance. Otherwise the hood wouldn't close properly.
How do you plan to install the 350Z cover?
Old Jul 4, 2006 | 11:06 AM
  #179
InTgr8r's Avatar
Originally Posted by G35 6MT
Good job!
No issues with the hood on my sedan...
RE the 350Z cover... similar to Eagle1 with a slot cut for the STB,
except I'll use a painted OEM.
Old Jul 4, 2006 | 07:14 PM
  #180
Mark350GT's Avatar
oh man, from the sounds of it i need to get one of these.
