defining brake wear
defining brake wear
Does anyone know what does [6mm left out of 11mm] equate to in % of wear for stock front brakes? I'm getting conflicting info from 2 diff dealers: one says I've got at least 50% left, while the other says i've got 15%.
which to believe?
since I've bought my used car 2003.5 here in Quebec Canada, the first dealer (who sold me the car) is obliged by law to change my breaks if they're more than 50% used on their dime (the 36k/3year warranty is over).. I just have the fealing the first dealer is trying to screw me over.
thx
which to believe?
thx
2mm is considered the unsafe point, however the thinner the insulative effect of the pad material the hotter the brake fluid gets [via conduction thru material, thru backing plate to piston].
The safety factor has to do with the caliper piston seals which gets stretched when pads are thin and rotors are thin..........so worn pads on new rotors are safer than worn pads on worn out rotors from the perspective of the possibility of seal failure and loss of brake pressure.
I always try to change pads BEFORE the 2mm point so 6 out of 2 means 4mm left you have used 5mm out of 9mm [usable] = 55% or 45% left to use.
Sensor squeels in reverse. The metal plate does not enter into the equation.........make sure you have 2mm [0.07874"] of actual pad compound when you replace.
Heck as cheap as oem pads are compared to a wreck [plus insurance increase] or hospital stay change them half worn...........same with tires.
ok I know this is simple math. But here's how they calculate it officially at the dealer:
(6-2mm)/(11-2mm) = 44% left for the fronts
(6-2mm)/(9-2mm) = 57% left for the rears
just an FYI
oh wait... q45tech did mention that....
just an FYI
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
