I want to get 350z springs for a slight drop and better cornering/handling. I have a 2004 (purchased in late 03), but I am going to get OEM 19s in the future. Do I need anything else besides the springs, like 350z strut bars, or anything else? Which springs do I need - 350z '04.5 and up? Am I going to have rubbing with 19s or a wierd frop that makes the back look raised. How much is a typical installtion price? Please help me out or give me recommendations, I appreciate everything!!
bump. c'mon, I know a lot of people know this. Can someone please help me out??
Z springs has been widely discussed here. I had so many questions before I ordered all my suspension upgrades and all found the answer by searching.
Are you getting the Z spring for free? did you consider getting the H-tech for 350Z and combo that with Tokico Dspec? Dspec/H-tech for 350Z seems to be a very popular combo in terms of performance and looks. This will not rub with your OEM 19's.
Z springs would be okay if you want a slight drop, however you should get 04.5+ if you don't want any bouncing problems at the back =)
Quote:
Originally Posted by Strtsk8r321
I have read not to buy tein springs.
myabe not the H-tech for the G. As far as i know the Z H-tech + Dspec combo is the cheapest performance/look combo you can get.what if I just get the H-tech springs? Is that better than OEM 350z springs '04.5+?
Definetly Better, read Gsedan35 sticy post, the H-tech for the 350z are linear spring and are stiffer than OEM spec whereas the G are progressive spring and the rear are softer than the OEM settings, the H-tech will give you both performance and looks!!
How is the ride quality compared to stock using the Z H tech? I know the performance will be improved but I'm concerned about ride quality.
What other combination would be a viable option if ride quality if my first priority, secondly, the most drop without having to go to a camber kit and thirdly, performance?
Please, I'm ready to go but just don't know which direction I should go. With all the experience on this board I'm hoping some of you can give me some ideas.
Thanks in advance, helpppppp please........
Mark
Mark
Quote:
The unrevised OEM Z springs, '03 and '04, aren't the culprits for the infamous bouncing. It was the unrevised OEM shocks.Originally Posted by godmans
Quote:
R U 100% sure? Can somone else confirm?Originally Posted by dklau33
Quote:
Think about it. The unrevised OEM 350Z springs have the same spring rates as a lot of the G35's. The only difference is in the free length of the spring.Originally Posted by Strtsk8r321
Quote:
Front:314 Rear:342
The thing responsible for the infamous bounce of the unrevised 350Z shocks was the valving. The revised 350Z shocks have a different valving that targeted that problem.Originally Posted by Gsedan35
Oem springs G35 coupes with oem 17’s & 18’s G35 sedan’s with sport suspension 350Z’s 2003/2004Front:314 Rear:342
