How Low Can I Go?
Old Mar 2, 2006 | 06:57 PM
G-TWIN's Avatar
How Low Can I Go?
WHAT IS THE LOWEST I CAN GO WITHOUT BUYING A CAMBER KIT? ALSO RIM ARE ON THE WAY 19x8.5 (26 OFFSET) 255/35/19 AND 19x10.5 (30 OFFSET) 285/ 35/19. TIRES ARE BFG KDW2. I'LL TAKE ARE THE INFO YOU GOT. I WAS THINKING 1 INCH DROP.
Old Mar 2, 2006 | 07:01 PM
drunkin master's Avatar
i think a one inch drop would be fine without any camber issues or atleast within oem spec. I have 20's with alittle over half an inch and my camber is perfect in the front and a fraction off in the back. Just get some good springs. I heard that tein s and high tech for the g's are horrible when it comes to spring rates.
Do a search and you should find more info and pics on the forums. I know that lot of people dropping an inch has 19's. Good luck.
post some pictures when you get it done.
Old Mar 2, 2006 | 07:10 PM
ONEmike's Avatar
I have tein s techs on my car right now, the springs are great and drop perfectly and eliminate the gap in the front. the rear however is a bit higher but if you were to get an aggressive rear offset the tein s techs should work fine. front drops around 1-1.1" and rear is a bit less at .7-.9".
Old Mar 2, 2006 | 07:17 PM
G-TWIN's Avatar
I Have Tein Master Flex. Do You Guys Think I Will Have Rubbing With The Tires 255 In The Front And 285 In The Back.
Old Mar 2, 2006 | 10:31 PM
G-TWIN's Avatar
Bump
Old Mar 3, 2006 | 01:56 AM
haze's Avatar
probably around 0.8" of drop and you can still get back to OEM spec without aftermarket correction kit. My rear dropped about 1" and it's slightly off OEM spec.
Old Mar 3, 2006 | 02:11 AM
you off set will play in effect on that
Old Mar 3, 2006 | 05:30 PM
G-TWIN's Avatar
how would the offset come to play? front 19x8.5 30 offset and 19x10.5 30 offset (speed star wheels d5r)
Old Mar 3, 2006 | 11:12 PM
Cactus's Avatar
I was wondering this about the rears in 285 also. I would prolly do a fender roll to be on the safe side.
Old Mar 4, 2006 | 10:25 AM
G-TWIN's Avatar
thanks cactus for the tip. i was thinking the same thing.
Old Mar 5, 2006 | 12:57 PM
G-TWIN's Avatar
stump
Old Mar 5, 2006 | 01:00 PM
ttrank's Avatar
Grocery getter
With a 1" drop your camber will be a bit off, probably just out of the factory max. If you take care of your tires and have them rotated often (including swaping them on the wheels every couple rotations) they will still last a long time and it will perform great.
DRG35R
Jan 31, 2016 07:14 AM
Rinaldi
Dec 2, 2015 05:29 PM
aaron3719
Sep 29, 2015 10:12 AM
wow600rr
Sep 28, 2015 11:50 AM
Detailed Image
Sep 28, 2015 07:04 AM
