too much camber?
Old Mar 3, 2006 | 01:24 PM
achampagne@shre's Avatar
too much camber?
Do all G35 Coupes 2004 have a problem with Camber settings going out of spec after some time or does the car come this way form the factory. My car was so far out of Toe and Camber it was rediculous. What has the factory done with regard to warranty, fixes etc. How have other owners overcome this problem?
Old Mar 3, 2006 | 01:33 PM
drunkin master's Avatar
looks like you have the 19 inch oem wheels. Most of the g's have some camber on the rear. Take it to the dealer and let them know that your camber and toe is off. I think they will take care of it for you. If not get some paper work showing your numbers on the camber & toe and make sure you show it to the dealer. Good luck
Old Mar 6, 2006 | 09:07 AM
Car is going in again today. I have the alignment numbers from three weeks ago when they did try to address the camber issues. LF, LR and RR wheels remain out of spec. Left rear is out by more then 1 degree. I am using 18" factory wheels with the Michelin Pilot tires. I don't believe they can fix the problem utilizing stock parts on the car, the have no room left on the adjustment. It will be interesting to see what solution they come up with.
Old Mar 17, 2006 | 06:09 PM
abunai's Avatar
im glad im not the only one with this problem... i just they all came with jacked up camber... dont they know tires aint cheap!
Old Mar 17, 2006 | 09:40 PM
kenchan's Avatar
my car had tremendous amount of toe-in so i just had it aligned.
i could tell the tires were starting to feather only after a few hundred miles.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Rose M
Oct 12, 2015 10:00 AM
