Dropping with Stock 19"s!
Old Mar 10, 2006 | 02:51 AM
aleok's Avatar
will i rub the fender if i drop the car lets say 2" (i know its not really reasonable). is the limit on how low i can go b4 rubbing? thanks
Old Mar 10, 2006 | 03:10 AM
808_G35's Avatar
no you wont..u got the stock tire size?? my rears are an inch close to the rim..and tucking some tire and it doesnt rub..the fronts are tuckin a lil bit of tire and doesnt rub..if u get a camber kit it might rub on the rear..not sure but if ur jus gona drop it, then u should have no problem
Old Mar 10, 2006 | 02:57 PM
skylar's Avatar
^ yups, you wont rub at all... did you see jdbinspired's g... he's currently running on oem 19's and his g is slammed.
Old Mar 10, 2006 | 04:11 PM
808HerbzG35's Avatar
^LOL, again, JD's G is a good case study. Skylar, you forgot to mention lastnight's spotted of a slam DG06/OEM19s on tiens, so yeah he too is "safe slammed."
Old Mar 10, 2006 | 04:51 PM
sngpimpin's Avatar
damn that is freaking low
Old Mar 11, 2006 | 05:34 AM
aleok's Avatar
k shoots
Old Mar 11, 2006 | 05:36 AM
aleok's Avatar
wait jdbinspired has HSK coils right?
Old Mar 11, 2006 | 07:09 PM
kenchan's Avatar
try some 15mm or 20mm offset spacers.
Old Mar 11, 2006 | 08:42 PM
skylar's Avatar
yup, he's slammed on HKS RS coilovers... his front is set to the lowest settings... as for the rear he had to modify it a little to slam it even more.
jsimonk
Dec 22, 2023 03:49 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
joedaddy1
Jul 28, 2015 02:58 PM
Karnicle
Jul 23, 2015 05:08 AM
