Lowered...alignment results...not happy.
Old Mar 13, 2006 | 01:51 PM
triniG35's Avatar
Please read:
I lowered the car a little over a month ago with rsr down springs and tokico d-spec shocks, both 350Z versions. I love moderate speed street driving, however at high speeds (hiway), the car does not seem stable (I drive 80% hiway). On the stock suspension I would jerk the wheel to switch lanes at high speeds (70-80) and the car responded great. Now when I do that, the car sways a little even after the lane change has already been made (like its stablizing itself of something!?)
Also, when driving constantly (40 mph) on hiway on/off ramps, the anti slip comes on (w/ light on dash) and holds/jerks the car back.
I know my camber is off and I need more toe-in. Is this what's causing it? Could my Tokicos be defective? The shocks are set at 4 turns from full hard.
I love the look and ride comfort, but I feel like going back to stock. (Though it will be hard after seeing the car lowerd!)
1st alignment 4-6 days after drop. 2nd today 3/13.
Please tell me what you guys think?
Old Mar 13, 2006 | 03:00 PM
drunkin master's Avatar
Are you rubbing at all? What size wheels and tires do you have?
Hard to tell whats going on. I recently dropped my car as well but with just springs (espelir gt-.5 drop all around) and my rear wheels rubbed when I turned and launched the car. I had my fenders cut and now its fine.
Your problem could be caused by lots of different issues.
Old Mar 13, 2006 | 04:22 PM
triniG35's Avatar
Yes, I agree that it can be many issues. I currently have the OEM 18 wheels. Fortunately no suspension noises and no rubbing whatsoever.
Old Mar 13, 2006 | 05:26 PM
G35pm's Avatar
Fix your rear toe. If anything, your rear tires will wear quick if you don't fix that. I set my total rear toe @ 0.00.
I used to have tokicos and didn't like them. I thought they were slow to react to what the car was doing. Maybe you should set them stiffer.
Old Mar 13, 2006 | 07:41 PM
CrazyMike's Avatar
Your unstable feeling is your toe. Give it about .08 degrees total toe-in up front and .16 degrees total toe-in out the back and you'll notice a big difference. I'm not sure why they gave you so little! I autox with mine at 0.0 degrees up front and the rears the same as I recommend for you. The front toe set to zero gives quicker intial turn-in but definatley can feel 'wandery' on the highway.
Old Mar 13, 2006 | 08:39 PM
kenchan's Avatar
triniG35- what swaybar setting are you using? are you on factory
swaybars? if so, i'd go 3 turns from full hard. if not, i recommend
you get a stillen set. your springs are probably too soft.
You definitely need more toe-in on the rear. the FINAL(AFTER)
setting doesn't even look like your alignment shop did any work.
it's almost like a reflection of your INITIAL (BEFORE). Did they even
align your car?! they seem to fix the front toe-out and that's about
it.
Here's what you want to aim for (this is more for tire wear):
Front toe: 0.03 each side
Rear toe: 0.08 to 0.10 each side
Camber: -1.5(rear-only) within 0.2 degrees left and right
If you have a-arms for the front, i would set it at -1.0.
Old Mar 13, 2006 | 10:06 PM
triniG35's Avatar
Thanks for the replies. I figured my toe had a lot to do with it. Ken, are you saying that more toe in = more tire wear? Cuz I do a lot of driving, esp on the hiway.
Eomfd
Aug 29, 2015 12:42 AM
mjfenix
Jul 14, 2015 10:37 PM
G35_Girl_69
Feb 27, 2006 08:06 PM
eledin
Canada
Feb 23, 2006 03:46 PM
