H-Tech (350z) ok on stock strut? do I need a camber kit? PLEASE HELP!
Old Mar 16, 2006 | 10:44 AM
MahdiG35's Avatar
G RIDIN
Exclamation H-Tech (350z) ok on stock strut? do I need a camber kit? PLEASE HELP!
hey wuz up
I am looking to get the 350z H. Tech, and I was wondering do I need to change my OEM struts and do I need to get a camber kit?
Thanks
Mahdi
Old Mar 16, 2006 | 11:03 AM
CrazyMike's Avatar
You won't need a camber kit - the front camber will be out of spec ~-1.5 degrees. However, this won't really cause significantly worse tire wear. The front and rear toe, as well as rear camber will be adjustable to specs. Just make sure they align the rear camber to a greater magnitude than the front (this will keep some of the safer understeer bias). I'd recommend -1.7 to -2.0 degrees camber in the rear.
Your stock struts should be OK, but they will have work a little harder than they were designed for (particularly the fronts). Basically the springs will be slightly under-damped compared to the stock setup.
If you can shell out a little more, I'd recommend getting a set of D-Specs ~$550 to put with these springs, but if you are really on a budget, the H-Techs on stock struts will work OK...
Old Mar 16, 2006 | 11:08 AM
pdjafari's Avatar
yup i have the same setup....350z h techs on stock...i might upgrade shocks in another year or 2 just to be safe....camber's a bit off i can see by looking at my wheels/tires...but nothing an alignment cant hopefully fix...
love the setup by the way...ride qualitys a bit stiffer but i like it
Old Mar 16, 2006 | 05:48 PM
fireblade's Avatar
What about s techs guys? Reason I want 350z s techs is because i want it a bit lower than 0.8/0.6". Think 1.1/1" with S techs would require camber kit?
Old Mar 16, 2006 | 08:51 PM
MahdiG35's Avatar
G RIDIN
so the camber is going to be off a little but they can get it right w/o a camber kit??
Thanks a lot for the help
Mahdi
Old Mar 16, 2006 | 11:38 PM
redlude97's Avatar
Mahdi
The front camber isn't adjustable, and it will be off. It is up to you if you want to live with that or not. Rear is adjustable but you won't be able to bring it back within specs either, so you'll be slightly off on both front and rear. If you can live with this, and get an alignment to have the toe adjusted to within specs, then you might be able to get by without camber kits.
Old Mar 16, 2006 | 11:48 PM
MahdiG35's Avatar
G RIDIN
ohh ok^^
thanks a lot!!!
Mahdi
jsimonk
Dec 22, 2023 03:49 PM
socalg35x
Aug 7, 2015 09:36 AM
julian.dion
Lighting
Jul 29, 2015 08:33 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
nascarbuff17
Jul 16, 2015 10:23 AM
