<-Can I switch my stock OEM 06 Coupe brakes with OEM Brembos?->
Old Mar 19, 2006 | 06:08 PM
MahdiG35's Avatar
G RIDIN
Question <-Can I switch my stock OEM 06 Coupe brakes with OEM Brembos?->
Hey
I was wondering if I can switch out my stock brakes to OEM Brembo brakes?? What modifactions do I have to do? Is it worth the trouble and money?? How much dose a used set of Brembos usally cost (front+rear)?
I did search and could not find any info about it.
Thanks
Mahdi
Old Mar 19, 2006 | 06:13 PM
Potty_Pants's Avatar
yes
unknown
no
dont think you can find a used set
the stock brembos provide sustained heat dissapation better then stock. however unless your doing track stuff its not worth the trouble & $$. plus they wear quite a bit faster then stock and will cost more to replace.
the reason you havent found much on stock brembos (upgrade) is they are marginally better then stock and for the money ( of the upgrade ) your much better getting an after market kit.
unless im mistaken kits run around 2k (discs,shoes,caliper)
ppp
Old Mar 19, 2006 | 07:11 PM
Klubbheads's Avatar
thinking of doing the same thing near future. More info would be apriciated.
Old Mar 19, 2006 | 07:24 PM
silvernole12's Avatar
I'm about to do the swap on my 05 hopefully this coming up weekend. I plan to do a write up on everything you need and have pictures. I'm just waiting on my calipers to come back from powder coat.
Old Mar 20, 2006 | 02:02 AM
kenchan's Avatar
Old Mar 20, 2006 | 02:09 AM
MahdiG35's Avatar
G RIDIN
how much did you get the OEM brembos for? (if you don't mind me asking)
That sounds great man! looking foward to seeing the pics
Mahdi
Old Mar 20, 2006 | 07:36 PM
I got just the calipers and pads for about 1300. I decided to buy own pads, new EBC rotors, and the other stuff.
Old Mar 21, 2006 | 12:58 PM
MahdiG35's Avatar
G RIDIN
sounds like a good idea!! Good luck and keep us posted
Old Mar 25, 2006 | 11:33 AM
MahdiG35's Avatar
G RIDIN
hey silvernole12, any updates???
Mahdi
Old Mar 25, 2006 | 05:38 PM
Tonys-G's Avatar
I have done this about 6 months ago and did just a small write-up on it
the only problem you will find is if you are using the Brembo rotors, then you have to cut back some of the dust shield on the rear, the fronts are a one for one swap
Old Mar 25, 2006 | 05:40 PM
Tonys-G's Avatar
if you are just changing out the calipers and pads then there should be an issue with the dust shield except maybe cutting enough room for the Calipers to fit on the rear since the OEM calipers were smaller than the Brembo's
Old Mar 25, 2006 | 05:42 PM
MikeyMike's Avatar
Rollin On Dubz
Everyone is going to jump on me for suggesting this, but I don't care...
have you considered painting your calipers?
Old Mar 25, 2006 | 06:48 PM
Tonys-G's Avatar
I love the Gold color too much, plus it goes with the blue
even though I did see a posting the other day of some blue painted Brmebos that looked awsome
Old Mar 26, 2006 | 04:06 AM
MahdiG35's Avatar
G RIDIN
Did you have to get new brackets for it??? or did it just bolt up?? Can we get like a OEM Brembo Dustshield and switch with the old ones?? would that work?? Thanks a lot!!
I just read your post, I am kinda confused on the rear, So I am going to need to get some extra bolts for it??
AGAIN THANKS A LOT!
Mahdi
Old Mar 26, 2006 | 05:27 PM
We just finished doing the swap on my car.
Here is what we learned.
1. The brembo calipers bolt up to the stock 05 brackets just fine.
2. The rear dust shields had to be cut/removed to clear the brembo calipers and the new rotors.
3. You will need either aftermarket stainless brake lines or the rubber/hard lines from the brembo car. I used Goodridge lines and worked just fine.
4. Tony-G mentioned that maybe the stock rear caliper mounting bolts will not screw in properly into the brembo rear calipers. We were trying to get done that I did not verify if that was true or not. I went ahead and bought new brembo caliper mounting bolts/washers for both the front and rear just in case. I didn't want to be stuck if something didnt fit right.
5. THey look hot sex compared to my stockers lol
Here are some teaser pics till I can do a full shoot with my wheels.
