RAS & Lowering
Old Mar 28, 2006 | 05:05 PM
keib's Avatar
RAS & Lowering
My search is coming up empty, but there have to be some threads on the issue.
Rear Active Steering and Lowering. The only comments I have read have been rather vague..."it may complicate it"..."can't lower with RAS, etc."
Would someone mind giving me the skinny? My stock look suits me, but soon moving into volks with a 245/275 setup and the gap will likely trouble me.
Thanks in advance for any help!
Old Mar 29, 2006 | 06:38 AM
MechEE's Avatar
If you aren't worried about running different offset and width rims with your RAS, I wouldn't worry too much about lowering it. Just make sure to get it back in to alignment spec. The issue is that the some of the aftermarket toe correction hardware is uncomfirmed to work with the new RAS hardware in the back (your toe arms now tie to a steering rack instead of to the body).
Old Mar 30, 2006 | 09:10 AM
keib's Avatar
Thanks for the response Mechee
Should I be worried about running different offset & width with the RAS?
Moving into a set of Challenges 8.5/9.5 245/35 & 275/35. I don't wish to slam the car...but enough where the gap isn't glaring.
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
