Another G sedan with 350z suspension *PIX*
#391
I just put Megan racing 350z springs on my g35x and MAN I swear my car is lower than yours... I'm almost considering raising it an holding out for coil overs. How low are you in the front? Front of car to ground?
#394
#396
Wheel gap not even?
I just had 2005 350z shocks/struts with 2003 Z springs up front and 2003 G coupe springs in back installed on my 2003 G35 Sedan today.
I was hoping the wheel gap would be even at all 4 corners, however, the rear has a 2 finger gap and the front has a 3 finger gap with this new setup
. Does anyone now if the gap will even out over time? I'm hoping the weight of the engine will drop the front down????
![52](https://g35driver.com/forums/images/smilies/52.gif)
#397
#398
I used the coupon code A7H4T5 and the price for the entire set was $330. I have this set up with the 2003 350Z springs up front and 2003 G35 Coupe springs in the rear. I really like the way they feel.
Rjblayz (02-06-2013)
#399
Hi guys!
i have a chance to buy 350z oem springs+shocks/struts all around is very cheap. And i have one question: will I have some problems in the normally operation of suspension? i have NV35 Skyline, and as you know, suspension of AWD 35Sky different from the RWD suspension. Maybe, should i to install springs only? Task of this install is dropping down
I'll glad to listen all your thoughts. Unfortunately, i couldn't search this info in Ru-net. I'm sorry for my "english".
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
#400
on
Hi guys!
flammable (07-05-2013)
#401
#402
#404
Just put Z springs, KYB's and Whiteline compression/lower control arm bushings on my 03 sedan and damn, I am so happy with the results. Feels like a different (better) car. Wish I had done this a few years ago when I got it. I'll post pics when the weather clears up enough to wash it and take some. Props to the contributors to this thread. It was a big help.
Edit: more pics here...
https://g35driver.com/forums/media-s...ml#post6845023
![Name: CocoSusp1-2_zpse3db897e.jpg
Size: 219.7 KB](https://g35driver.com/forums/attachments/brakes-suspension/193762d1501294608-another-g-sedan-350z-suspension-pix-cocosusp1-2_zpse3db897e.jpg)
#405
I finally got my '05 350z struts with front 03 Z springs and rear 03 G coupe springs. Very happy with the results the handling is awesome compared to stock none sport suspension. I Also got the stillen sways put on from a group buy on this site. I had one question about the stillen sways, did anyone have problems fitting the front sway setting on medium? right now I have front soft and rear medium.
![](http://i8.photobucket.com/albums/a17/Danaw123/100_2244.jpg)
![](http://i8.photobucket.com/albums/a17/Danaw123/100_2243.jpg)
![](http://i8.photobucket.com/albums/a17/Danaw123/100_2242.jpg)
![](http://i8.photobucket.com/albums/a17/Danaw123/112_1251.jpg)
![](http://i8.photobucket.com/albums/a17/Danaw123/033006_10301.jpg)
![](http://i8.photobucket.com/albums/a17/Danaw123/032206_15071.jpg)
![](http://i8.photobucket.com/albums/a17/Danaw123/032306_11461.jpg)
