Another G sedan with 350z suspension *PIX*
Old 04-17-2011, 08:02 PM
JacekPSUr6's Avatar
Here is my G/Z suspension swap contribution:
  #347
Old 04-22-2011, 05:05 AM
Dreamin4Awhile's Avatar
can u do this on a 05 g35x? just seeing if it would be cheaper to do this than replace the entire control arm as they dont sell a decent ball joint replacement. Just pm me if u have any info.
Thanks
  #348
Old 04-23-2011, 11:53 AM
QUiKSR20's Avatar
My G/Z Contribution.. 06 6MT RWD
This is the way it should of come from the factory just like the stance on any BMW / Mercedes STOCK
  #349
Old 05-08-2011, 11:19 PM
g35sweetness's Avatar
i have a 2004.5 350z full suspension strut coil spring in the classified for sale, lmk
  #350
Old 07-10-2011, 02:47 PM
stevo4756's Avatar
Ok so I spent hours reading through this and I haven't really found a straightforward answer so I'm going to ask...
I have a 03 sedan on a staggered set of rims. 19s in front, 20s in back. The rear suspension gives too much (car squats too much in the rear on full throttle, up steep driveways one side seems to travel all the way to the point that the 20s rub on the top inside of the fender , also on huge bumps while driving the wheels seem to move up and down too much) .
As far as I know the car does not have the sport suspension but im not 100% on that.
Is it possible to stiffen things up in the rear without having to drop? Or is this a good sign that the suspension is worn?
I just had the front right shock replaced and the car has about 120k miles...
  #351
Old 08-04-2011, 08:14 PM
Herbbie Hablib's Avatar
Maybe you guys could help me out, I have a 06 Sedan 6mt and the struts are black, does this mean i have NON sport suspension?
Thanks
  #352
Old 08-04-2011, 08:15 PM
JacekPSUr6's Avatar
^ yes
  #353
Old 08-04-2011, 08:19 PM
Jesus christ that was quick i dont think my page had even totally refreshed before you replied thanks man!
I have the Z/G springs sitting at home so im excited now that i know i have non sport so should be a nice difference in ride. Im debating the Blues or D-specs for stuts.
  #354
Old 08-04-2011, 11:46 PM
trentor's Avatar
There was no way to get non-sport struts on a 6MT, so someone has swapped them already. It might be worth your while to clean them off & find a part number. It's unlikely, but you may have some good performance struts on there already, which could save you some $. On the other hand, someone could have thrown base model struts on it, so it's worth a look.
  #355
Old 08-04-2011, 11:50 PM
NFSP G35's Avatar
? = 2B || !2B
^Good call! I didn't even think about that, but you're right.
  #356
Old 08-05-2011, 10:46 AM
brandon1978's Avatar
In 2006 the sport struts/shocks were black not red.
  #357
Old 08-05-2011, 03:33 PM
colinhuemmer's Avatar
I have one very simple question, Ive tried searching and have not ben able to find an answer . WIll 2008 350z NISMO complete suspension fit (with no altering or fabricating) onto my 2005 G sedan ? I could really use some help with this question
  #358
Old 08-05-2011, 06:22 PM
So guess i do ha, well sweet! It did ride pretty stiff for "stock" but i like the ride stiffer Still will prolly go for the Blues for struts. The car is bone stock un molested when i bought it with 30,000 miles. When i get back in the ol usa ill pull some numbers.
Thanks guys
  #359
Old 08-05-2011, 08:23 PM
NFSP G35's Avatar
? = 2B || !2B
I don't know of any reason why it wouldn't
  #360
Old 08-12-2011, 06:32 PM
deegaw11's Avatar
I just bought a full oem 03 350Z suspension including shocks and springs. Will I get alot of bounce if I install them on a 04 coupe? At first I wanted to only lower slightly and keep the stock ride quality but now I've read alot of people are complaining about bounce.
Should I install them or not? Please let me know so I don't end up putting them on and regret.
Quick Reply: Another G sedan with 350z suspension *PIX*
