squeaking brembo's after replacing. normal or not?
I got 04 brembo pads and rotors re-surfaced replaced and now my brakes are squeaking like a ****. Mostly at low speeds NOT if I brake hard.
I know this a brembo characteristic but I don't think I've had this much loud squeaking before.
I didn't get this before either with my worn pads
On a side note, how much did it cost you and where you got the parts?
Originally Posted by TheKnite
I think people on here recommend using something to stop the squeaking when replacing pads.
i want to know what that is...
I got it replaced under warranty at infiniti, all OEM parts.
I guess I could go to autozone and grab a can of that... "stuff"
On a side note, if you wanted to try the brake stuff people are talking about it's a red silicone called "Disc Brake Quiet" http://www.autobarn.net/ch05016.html and can be purchased at most major hardware stores. IMHO though you should take it right back to the dealer!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
