problem with suspension?
Old Apr 4, 2006 | 10:27 PM
LeeR104's Avatar
hey guys,
car's running great. got my z tube and stillen hi flow installed...can't wipe the smile off my face (now that i'm passed my break in)
anyways, i know i'm not being paranoid because i've checked on different surfaces and looked at it from every angle. my driver side rear seems to be riding low...OR my passenger rear is riding high. not sure if i'm describing it well enough for any of you guys to understand. also, the driver side front seems to be a little higher than the passenger front. so basically it seems lopsided...
i have an 06 6mt coupe with rear steer assist (just covering basics) i hope somebody knows what's going on so i know what i'm dealing with. TIA for the help
Old Apr 5, 2006 | 09:43 AM
HillBilly's Avatar
Obvious but practical
Try to take some measurments on the flat surface to be sure.
Measure from the ground to the same point on either side and that will let you know for sure. (Their are some specific measure points from the ground to the suspension that you can measure to determine ride height but I am not sure what they are off hand.) If they are different I would double check the tire pressure on all 4 tires and be sure that they are the same and remeasure.
After that go to the dealership. You know they love us car crazy people who know more than they do about the car and have standards that their "normal" customers don't even consider.
Old Apr 5, 2006 | 12:18 PM
Q45tech's Avatar
Be sure to measure with your weight in drivers seat and oem design is for a 150 pound driver..........obviously weight variances and fuel load will change ride heights [corner variances]
Old Apr 5, 2006 | 12:24 PM
PEPPY's Avatar
my drivers front is 1/4" lower than the other corners. I checked from the ground to the bottom of the body, & also from the inner wheel wells to the center wheel hub. seems to be off the same amount.
Old Apr 5, 2006 | 03:42 PM
fireblade's Avatar
Are you a fat and huge? That could be it....
Old Apr 5, 2006 | 03:47 PM
speedracerg35's Avatar
easiest way to check is to measure the gap between your tires and fender/quarter panels. take it in if it is off.
Old Apr 6, 2006 | 12:16 AM
LeeR104's Avatar
this is what i did to come to the conclusion that my heights were off. i already scheduled an appointment for friday. hopefully it's nothing too drastic. sucks to have problems already though :\
Old Apr 6, 2006 | 04:05 AM
aleok's Avatar
tire pressure?
Old Apr 6, 2006 | 02:40 PM
LeeR104's Avatar
tire pressure is the same...plus i don't think it would matter with the pressure. i wish i could explain it better. let's just say one side looks 'tucked' and the other side looks 'normal'. or at least more normal than the other. either both sides should be tucked or both normal. :\
hopefully the dealership will have a solution.
Old Apr 10, 2006 | 12:22 PM
HillBilly's Avatar
What happened
Did you find out what the solution was?
Old Aug 27, 2009 | 09:48 PM
G35fromTO's Avatar
Exclamation Bump - please look at last post. Need info.
Didn't want to start a new thread. Does anyone know how this sort of issue can be resolved? Is there an adjustment that can be done?
Searched the forum, and pretty much all threads would leave off without how the issue was resolved.
Thanks in advance.
snic09
Nov 8, 2017 01:46 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
TreeFiddy
Aug 10, 2015 06:50 PM
Fireman07603
Aug 9, 2015 06:00 PM
atk08
Jul 30, 2015 03:12 PM
