cutting springs?
Old Apr 12, 2006 | 12:14 AM
haze's Avatar
Originally Posted by jwebb82rez
NO PLEASE GOD NO!!
Sell the springs and get something different. Here is my car with 350Z Eibachs. Look into getting the 350z model springs instead of the models made for the G. FYI The third picture listed is for the rear, you said yours was too high.
https://g35driver.com/forums/attachm...9&d=1141622462
https://g35driver.com/forums/attachm...7&d=1141622462
https://g35driver.com/forums/attachm...8&d=1141622462
wow.... ok u guys have convinced me. nice drop !!!
Old Apr 12, 2006 | 01:07 AM
Gsedan35's Avatar
NO PLEASE GOD NO!!
Not a good choice for use with any shock other then 05/06 coupe sport suspension shocks, oem 04.5+ Z shocks, D-specs or Koni's.
Old Apr 12, 2006 | 01:15 PM
FenixL1P's Avatar
Originally Posted by kenchan
basically it's like taking your ruler at 12in length and bending it.
now cut it in half and try bending it. it takes more force to bend.
a coil spring, when cut, will still have the same spring rate as it did before the cut due to the axial and toradial forces compressing the springs.. your analogy with the ruler is closer to leaf springs like that used on the corvette rears.... the coil spring will just have less travel but the spring constant stays the same... if and only if no excess heat was used while cutting it....
Old Apr 12, 2006 | 09:02 PM
Sponger's Avatar
6MT Brembo Coupe
Ken, I was actually looking for detailed instruction on trimming the rubber mount to lower the rear. Thanks.
Old Apr 12, 2006 | 09:04 PM
s14roller's Avatar
Originally Posted by inTgr8r
LOL.. when did this turn into a Civic forum
lol...
Old Apr 12, 2006 | 10:42 PM
kenchan's Avatar
gsedan35 did it on his sedan. he said to use lots of WD40 and use a
saw to cut the mount. that's all..not really much to it.
Old Apr 13, 2006 | 02:28 AM
Gsedan35's Avatar
spring rate is a function of wire diameter, coil diameter and the number of active coil's. Remove and reduce the number of active coils (cutting them out) and spring rate goes up.
Example.
Wire diameter .57”
Spring O.D. 4.61”
Number active coils 6
spring rate 375lbs
same but with 5 active coils
spring rate 450lbs
This is why cutting springs is a no no. I can take the discussion into area's of oem dampning limitation's and insuffecient bump travel, but don't see the point.
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
