Suspension Click Noise
Old Apr 3, 2006 | 07:00 PM
  #31
tdotG's Avatar
I have 65,000 km on my '03 Coupe still under warranty until 80,000 km. Does anyone know if this TSB is covered under my warranty or will I need to pay anything? I brought my car in for a TSB regarding a rattle at 45,000km and the dealer made me pay a labour cost because I was past 12 months on the car. He said TSBs are not Recalls so I still have to pay to have the service done. Is that true?
Old Apr 3, 2006 | 09:36 PM
  #32
conq's Avatar
Hey tdotG, your dealer ripped you off. Those repairs are done under warranty, there's no cost. Call infiniti consumer affairs and complain.
Old Apr 12, 2006 | 01:54 PM
  #33
joshlee's Avatar
i went into the dealer at around 20k miles on my car and it was lowered on HKS coilovers...they replaced it without hasslin me bout lowered suspension...it was done at the montclair dealers next to pomona...try checkin there...and ask for keith and tell him josh recommended him
Old Nov 14, 2006 | 05:19 AM
  #34
JC-RH's Avatar
what did they replace?? was the issue fixed?
Old May 4, 2008 | 02:09 AM
  #35
Strtsk8r321's Avatar
Old thread. But at 59,000 miles with my new wheels this started happening to me. My warranty is up, what should I do about it?
Old Jul 29, 2008 | 03:26 PM
  #36
Rich83's Avatar
i have the same problem when i start to accelerate and same thing while getting on the brakes..i hear this freaking noise.. the noise is coming from the rear driver side.. i read this thread and there are many different solutions.. my car is no longer under warranty..
now what is the problem? is it the rotor making the noise? is it the Outer Axle Joint? or is it the Wheel Bearing?
OR
can i just replace the rear sway bar link?
OR
is it loose suspension parts?
can some one please respond and help me out
Old Jul 29, 2008 | 07:34 PM
  #37
RBull's Avatar
Rated M
It sounds like you simply need the rear axle click TSB.
Old Jul 30, 2008 | 10:43 AM
  #38
KSWAY's Avatar
Mine is doing the same thing. So this is covered under TSB?
Either way i will need to get this fix because it's getting fkn annoying.
I still have about 15K left on the extended warranty so hopefully that
will cover it if it's not covered under the TSB.
Old Jul 30, 2008 | 10:51 AM
  #39
KSWAY's Avatar
DAMNNNNNNNNNNNNNN Check this out..
G35 RECALLS & TSB's
[B]Here's a comprehensive list of G35 RECALLS & TSB's I found on a BMW forum.
Some guy on there was dissing the G35. But it kind'a backfired because several BMW guys who had G35's argued that they really liked the car & had very little trouble with their G's...
In the Four Years I had my G35 6mt Coupe, I had the 6 sp.manual trans. replaced, a window grease TSB & in for the Fuel Line recall. Besides that no problems with my G.
It was a Great Car and I wish I could have afforded to keep it but needed the down payment for our new BMW 335i convertible.
Anyway I thought this was some good info, just go down the list & see which ones might apply to your car...most all of these apply to "2002 & 2003 G35's"
Here are 6 major recalls. Nature of Defect:
1. FUEL:FUEL LINES:HOSES:NON-METALLIC Recall Number: 02V245000
Dates Manufactured: JAN 2002 to JUL 2002
Number of Vehicles Affected: 18300
Date Owners Notified On: SEP 2002
Vehicle: 2003 Infiniti G35
Defect Description:
THE FUEL HOSE CONNECTION FOR THE OUTLET OF THE FUEL PUMP WHICH IS LOCATED AT THE TOP OF THE FUEL TANK MAY NOT HAVE BEEN PROPERLY ATTACHED WHEN THE VEHICLE WAS ASSEMBLED AND COULD COME LOOSE WHILE DRIVING OR WHEN STARTING THE ENGINE.
Consequence of Defect:
IF THE CONNECTION COMES LOOSE WHILE DRIVING, THE ENGINE WILL STOP RUNNING DUE TO LACK OF FUEL, INCREASING THE RISK OF A CRASH. ALSO, IF THE CONNECTION COMES LOOSE WHILE DRIVING OR ATTEMPTING TO START OR RESTART THE ENGINE, SOME FUEL WILL DISCHARGE FROM THE FUEL PUMP. IF THIS SHOULD OCCUR IN THE PRESENCE OF AN EXTERNAL IGNITION SOURCE, A FIRE COULD RESULT.
Nature of Defect:
2. EXTERIOR LIGHTING:HEADLIGHTS Recall Number: 02V331000
Dates Manufactured: N/A to N/A
Number of Vehicles Affected: 36000
Date Owners Notified On: JAN 2003
Defect Description:
SEDANS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, -***244;LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.-***246; IN THE ASSEMBLY OF THE HEADLAMPS, IT IS NECESSARY TO HAVE A MEANS TO ADJUST THE HEADLAMPS. TAMPERPROOF CAPS TO PREVENT HORIZONTAL ADJUSTMENT OF THE HEADLAMPS ARE THEN INSTALLED. SOME OF THESE VEHICLES ARE MISSING THE TAMPERPROOF CAPS.
Nature of Defect:
3. SERVICE BRAKES, HYDRAULIC:SWITCHES:BRAKE LIGHT Recall Number: 03V200000
Dates Manufactured: AUG 2002 to MAR 2003
Number of Vehicles Affected: 60000
Date Owners Notified On: JUN 2003
Defect Description:
ON CERTAIN SEDAN AND COUPE MODEL VEHICLES, THE BRAKE STOP LAMP SWITCH MAY MALFUNCTION.
IF THIS OCCURS, THE BRAKE LAMPS WILL NOT ILLUMINATE WHEN THE BRAKE IS APPLIED, WHICH COULD RESULT IN A CRASH WITHOUT WARNING.
Nature of Defect:
4. ENGINE AND ENGINE COOLING Recall Number: 03V455000
Dates Manufactured: JAN 2002 to JUN 2002
Number of Vehicles Affected: 630000
Date Owners Notified On: N/A
Defect Description:
ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR OR CAM POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS.
THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH.
Nature of Defect:
5. FUEL SYSTEM, GASOLINE Recall Number: 05V555000
Dates Manufactured: NOV 2001 to OCT 2003
Number of Vehicles Affected: 192659
Defect Description:
ON CERTAIN PASSENGER AND SPORT UTILITY VEHICLES, THE FUEL FILLER HOSE MAY CRACK AND RESULT IN FUEL LEAKAGE FROM THE HOSE WHILE REFUELING.
FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE.
Corrective Action:
DEALERS WILL REPLACE THE FUEL FILLER HOSE. RECALL BEGAN ON FEBRUARY 27, 2006, FOR NISSAN OWNERS, AND ON MARCH 13, 2006, FOR INFINITI OWNERS. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200.
Nature of Defect:
6. EXTERIOR LIGHTING Recall Number: 06E060000
Number of Vehicles Affected: 87745
Defect Description:
CERTAIN AAI MOTORSPORTS COMBINATION LAMPS SOLD AS REPLACEMENT LAMPS FOR USE ON THE ABOVE LIST PASSENGER VEHICLES. COMBINATION LAMPS NOT EQUIPPED WITH AMBER SIDE REFLECTORS FAIL TO CONFORM WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, -***244;LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.-***246;
LACK OF AMBER SIDE REFLECTORS IN THE LAMPS WILL DECREASE LIGHTING VISIBILITY TO OTHER DRIVERS AND MAY POSSIBLY RESULT IN A VEHICLE CRASH
Here are 77 TSB Bulletins
Component Description:
1. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 06004
Bulletin Date: MAR 2006
Summary:
MALFUNCTION INDICATOR LAMP WITH DIAGNOSTIC TROUBLE CODE U1000 OR U1010 STORED IN ENGINE CONTROL UNIT. 2002 - 2006 INFINITI VEHICLES WITH CAN COMMUNICATION. ( NHTSA ITEM NUMBER - 10019293 )
2. SERVICE BRAKES, AIR:ANTILOCK:WHEEL SPEED SENSOR Bulletin Number: 03056A
Bulletin Date: NOV 2005
Summary:
ESSENTIAL TOOL J-45741-INF ABS ACTIVE WHEEL SENSOR CHECKER. ( NHTSA ITEM NUMBER - 10006124 )
3. POWER TRAIN:AXLE ASSEMBLY Bulletin Number: 05002
Summary:
CLICKING NOISE FROM REAR AXLES. ( NHTSA ITEM NUMBER - 10017773 )
4. SEATS Bulletin Number: 02080
Bulletin Date: JUL 2005
Summary:
DRIVER'S SEAT NOISE AND/OR ROCKS BACK AND FORTH. ( NHTSA ITEM NUMBER - 10016401 )
5. POWER TRAIN:AXLE ASSEMBLY Bulletin Number: 05002
Summary:
CLICKING NOISE IS COMING FROM THE LEFT AND/OR RIGHT REAR AXLE WHEN ACCELERATING FROM A STOP. ( NHTSA ITEM NUMBER - 10016567 )
6. STRUCTURE:BODY Bulletin Number: 05034
Bulletin Date: JUN 2005
Summary:
NOISE FROM REAR DOOR WITH WINDOW ALL THE WAY UP. ( NHTSA ITEM NUMBER - 10015415 )
7. ELECTRICAL SYSTEM:WIRING Bulletin Number: 04020
Bulletin Date: MAR 2005
Summary:
TRAILER LIGHT WIRING. TO INCLUDE INFINITI 2006 M35/M45. ( NHTSA ITEM NUMBER - 10012880 )
8. STEERING Bulletin Number: 03028A
Bulletin Date: SEP 2004
Summary:
STEERING DRIFT TO THE RIGHT. ( NHTSA ITEM NUMBER - 10005686 )
9. STRUCTURE:BODY Bulletin Number: 03052
Summary:
SQUEAK AND RATTLE REPAIR.COUPE ONLY. (NHTSA ITEM NUMBER - 10003435)
10. VISIBILITY:REARVIEW MIRRORS/DEVICES Bulletin Number: 04046
Summary:
RATTLE NOISE FROM REAR VIEW MIRROR HARNESS COVER. ( NHTSA ITEM NUMBER - 10009749 )
11. STRUCTURE:BODY Bulletin Number: 04035
Bulletin Date: AUG 2004
Summary:
RATTLE NOISE FROM REAR SIDE WINDOW FINISHER. ( NHTSA ITEM NUMBER - 10009175 )
12. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM) Bulletin Number: 04042
Summary:
NAVIGATION SYSTEM IS INOPERATIVE AND THE DISPLAY SHOWS DISC ERROR OR DVD-ROM VERSION IS NOT CORRECT. ( NHTSA ITEM NUMBER - 10009182 )
13. VISIBILITY:POWER WINDOW DEVICES AND CONTROLS Bulletin Number: 04033
Bulletin Date: JUL 2004
Summary:
WINDOW REGULATOR MOTOR RESET PROCEDURE. ( NHTSA ITEM NUMBER - 10009364 )
14. VISIBILITY:SUN ROOF ASSEMBLY Bulletin Number: 04024
Bulletin Date: MAY 2004
Summary:
SUNROOF LID SQUEAK/CREAK NOISE. ( NHTSA ITEM NUMBER - 10007679 )
15. INTERIOR LIGHTING Bulletin Number: 04019
Bulletin Date: APR 2004
Summary:
VANITY MIRROR MIRROR BULB REPLACEMENT. ( NHTSA ITEM NUMBER - 10007728 )
16. ELECTRICAL SYSTEM:WIRING Bulletin Number: 04020
Summary:
APPROPRIATE HOOKUP POINTS FOR CONNECTING A TRAILER LIGHTS WIRING HARNESS TO THE VEHICLE. ( NHTSA ITEM NUMBER - 10007727 )
17. ELECTRICAL SYSTEM Bulletin Number: 03055
Bulletin Date: FEB 2004
Summary:
BUZZ SOUND FROM METER CLUSTER AFTER IGNITION KEY IS TURNED OFF / TURN SIGNAL AND WARNING CHIME DO NOT SOUND. THIS REPLACES ITB03-055 DATED 8/20/03. ( NHTSA ITEM NUMBER - 10003514 )
18. SERVICE BRAKES, HYDRAULIC Bulletin Number: 03069A
Bulletin Date: JAN 2004
Summary:
REDUCTION OF FRONT BRAKE NOISE WHEN BRAKING IN REVERSE. THIS BULLETIN REPLACES ITB03-069. ( NHTSA ITEM NUMBER - 10005216 )
19. STRUCTURE:BODY Bulletin Number: 03050A
Summary:
SQUEAK AND RATTLE REPAIR. SEDAN ONLY.( NHTSA ITEM NUMBER -10005687)
20. STRUCTURE:BODY Bulletin Number: 03052A
Summary:
SQUEAK AND RATTLE REPAIR.COUPE ONLY.( NHTSA ITEM NUMBER - 10005688 )
21. EQUIPMENT Bulletin Number: 04001
Summary:
REMOTE KEYLESS ENTRY REPLACEMENT PARTS. ( NHTSA ITEM NUMBER - 10005194 )
22. STRUCTURE:BODY: DOOR Bulletin Number: 03071
Bulletin Date: DEC 2003
Summary:
RATTLE OR CREAK NOISE FROM TOP OF DOOR WINDOW FRAME. ( NHTSA ITEM NUMBER - 10005263 )
Old Jul 30, 2008 | 10:59 AM
  #40
Yv12345vY's Avatar
I love the driver!!!! This clicking started for me in the last few weeks. Going to call the dealer today and get them to fix it. Woooooooooooooo.
Old Jul 30, 2008 | 05:32 PM
  #41
Rich83's Avatar
will infiniti still fix the recall if the warranty has expired?
Old Aug 9, 2008 | 09:28 AM
  #42
Sals G35 Coupe's Avatar
I have an 05' Coupe that I bought used with 38k and the clicking noise has been occurring since day one. I am bringing it in Monday morning for the dealer to take a look at it. I have read that some of you brought the TSB with you and I would like to do the same because my dealer sucks. If they can get away with just greasing rather than performing any replacement then they will. I tried the direct link above, but it brings me to a Nissan website that requires a password. Am I doing something wrong? Is there another way to get the TSB?
Old Sep 21, 2008 | 08:29 AM
  #43
b43k's Avatar
First of all let me say 'what's up guys?' First post here. I don't have a G35 but I do have the same problem with my 2003 M45.
To Sals G35 Coupe: So did you end up getting your G fixed? I also am out of warranty and curious to know if a TSB repair is no charge or not. As for your problem with that direct link, I also had that problem so this is what I did:
1. go to: http://www.infiniti-techinfo.com/
2. register on that site
3. log back in then in the left side select 'Technical Service Bulletins' from the drop down menu.
4. click on 'G35 (V35) 03-07' then 'RA - REAR AXLE & SUSPENSION'
5. Then you should see the service bulletin ITB5002
Hope this helped and I'm gonna call the dealer tomorrow and see what they say but if anyone knows if this TSB repair is free even though the warranty expired, please let me know, thanks in advance!
Old Oct 19, 2008 | 04:26 AM
  #44
G35_RJ's Avatar
this forum is awesome... I just noticed the clicking today during acceleration from a stop. It was there months ago but I never bothered with it.. Did a search on the forum and got loads of information.
I'll be taking mines to the shop this week, thanks!!
Old Apr 28, 2009 | 10:27 PM
  #45
AARONHL's Avatar
I followed the TSB by greasing the axle end and the ticking/clicking noise is still noticeable. Should I try replacing the axle? I am also unsure if my rear wheel bearing is shot??
