can someone help! How do we replace the Brembo ROTORS?
Old May 3, 2006 | 06:51 PM
imRACERX's Avatar
Im looking all over and dont find on a search. i assume we need to remove the four bolts holding BREMBO calapers together with a large allan key but would like to be certain on the steps. the sooner the better as my car is jacked up with pads off. thanks RX
Old May 3, 2006 | 07:04 PM
Brando's Avatar
PM Sent
Old May 12, 2006 | 01:35 PM
elrooko's Avatar
I have the same question. About to put the rotorso on my car and sizing this up and would like instructions if you have them? Thanks
Old May 12, 2006 | 01:54 PM
afr0puff's Avatar
Supa Dupa Moderator
Unbolt the calipers and the rotor slides off. Depending on how much rust is there, it might require a few good whacks with a rubber mallot. Also make sure the E-brake is disengaged.
Old May 12, 2006 | 08:18 PM
elrooko's Avatar
By un bolt the caliper, do you mean the two bolts on the back of it? Is that all that needs to be done? Is there a Torque setting to pu them back to?
Old May 12, 2006 | 09:53 PM
Fassster10's Avatar
Hey Guys Question Of The Subject...how Much Is The Upgrade For The Brembo Brakes? Which Is The Best Place To Get Them? The Dealer Or Buy Them Online And Have Them Installed At The Dealer????
Old May 13, 2006 | 12:16 AM
afr0puff's Avatar
Supa Dupa Moderator
113-114 ft-lb.
Old May 13, 2006 | 11:10 AM
Diesel1's Avatar
Moderator
Originally Posted by afr0puff
113-114 ft-lb.
AKA ALOT!!!! Those ******* are on tight! BE sure not to let the caliper dangle by the brake lines. Be sure you have a bucket or sumtin ready to support the caliper! I believe the bolts holding the caliper are 21MM (give or take 1MM)
jsimonk
Dec 22, 2023 03:49 PM
Frankieg35
Mar 20, 2016 09:42 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
RedBaronK
Jul 27, 2015 03:19 PM
vstypicals
Jul 20, 2015 10:55 PM
