kg/mm super sport springs
Old May 12, 2006 | 11:15 AM
Back2VQ's Avatar
has anyone used (or is using) these springs on their coupe?
buddy has a set for sale and debating whether to use them or not...i have an 05 coupe 6mt (sport suspension).
Old May 13, 2006 | 01:05 AM
Back2VQ's Avatar
no one?
Old May 13, 2006 | 07:25 AM
Q45tech's Avatar
Kg/mm stands for kilograms per millimeter a metric unit of measurement.
It needs a number in front of this term to make any sense.
Not sure what you are alluding to, do you think this is a brand name?
Old May 13, 2006 | 10:35 AM
Back2VQ's Avatar
it IS a brand name...surprised you didn't know.
KG/mm spring link
Old May 13, 2006 | 11:58 AM
Gsedan35's Avatar
KG/mm spring link
He doesn't follow brands or what's avaliable for the platform, totally understandable since his area of expertise relates to owning or working in a shop, he's schooled as a SAE engineer IIRC.
Old May 13, 2006 | 12:01 PM
Gsedan35's Avatar
Btw,
Kg/mm springs 350Z
DR21 super sport 15mm drop
Spring rates in lbs initial/final front 246/398 initial/final rear 252/409
Pretty wide spread between initial and final spring rates. Looking at peak front rates, I'd look out for dampning issues in the front.
Old May 13, 2006 | 12:29 PM
Q45tech's Avatar
Well at least they didn't chose POUND/INCH, sure must sound weird to the rest of the world which uses metric............one of those brand names chosen to appeal to the American Masses without any technical training.
"Pretty wide spread between initial and final spring rates" corrected for offset motion ratio [divide by ~ 2] they appear about equal to what rear Eibach's run.
Old May 13, 2006 | 01:24 PM
Back2VQ's Avatar
Originally Posted by Gsedan35
Btw,
Kg/mm springs 350Z
what do the initial/final spring rates mean? does this mean as the springs settle down it'll be closer to the 398(f) 409(r) rates?
Kelvin Style006
May 23, 2016 03:47 AM
R350k5
Oct 1, 2015 08:41 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Jyounya
Sep 12, 2015 04:03 PM
spanky99l
Sep 7, 2015 12:46 AM
