stoptech front BBK lost to OEM
Old May 5, 2006 | 04:02 PM
ma_sha1's Avatar
http://www.sportcompactcarweb.com/tech/0210scc_zthrash/
just found this article,
any comments?
Old May 5, 2006 | 04:23 PM
StopTech's Avatar
As stated in the article, that kit was a prerelease kit on a a preproduction car and the article is in fact quite old. It was even noted in the article that the excess negative camber brought on by the aftermarket springs was responsible for the variation. A more recent representation of expected performance available here:
http://www.zeckhausen.com/testing_brakes.htm
Old May 5, 2006 | 07:27 PM
codeflux's Avatar
just what i thought as well. good article, though.
i love my 14" front and rear Stoptech BBK.
Old May 5, 2006 | 08:22 PM
Q45tech's Avatar
As you see you have to spend to increase acceleration or braking horsepower.
2.5% improved stopping distances are a big deal and difficult and expensive to accomplish.
Even with RE040, tires are the limiting item to decreasing stopping distance.
Need tires that wear out in a few thousand miles.
Old May 5, 2006 | 09:27 PM
OOOOA3's Avatar
Alumni****
Yeah, tires are definitely the biggest factor. You can have the strongest brakes, but with tires that don't grip or lack tread, you won't stop any better than the OEMs.
Old May 6, 2006 | 11:02 AM
cato's Avatar
SouthernComfort Moderator
Yeah...I's actually the tires that stop the car.
Old May 6, 2006 | 03:34 PM
Q45tech's Avatar
"with tires that don't grip or lack tread,"
Tread is only partially useful in wet [tread to void ratio] and not at all useful in dry.........fast wearing slicks that have fresh sticky not hardened rubber.
Old May 6, 2006 | 05:17 PM
StopTech's Avatar
Its really quite interesting to see the effect of tires on similarly equipped cars as in the recent RSX challenge.
http://www.stoptech.com/company_info...hallenge.shtml
The 1st place car used Hoosier A3S05:
While the 2nd place car ran Yokohama A032R-S:
Both cars used the same StopTech brake kit but the Hoosiers stopped 14 feet shorter.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
EPG35
Aug 16, 2015 04:52 PM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
