AP Racing Front and Rear Brake Upgrade
Old Oct 24, 2006 | 09:47 AM
DaveG@Altered's Avatar
We have a set of AP Racing brakes that we installed on a customer car then he decided he did not want them. The car never touched the ground. So, We are selling them at cost.
Fronts- 6-Piston calipers and 363mm (14.25") high performance two piece drilled and slotted rotors . We chose to develop our "NEW" Big Brake Upgrade for the 350Z and G35 using this latest technology. Originally Developed to meet the stringent standards of Select OE manufactures building High performance vehicles. This kit will also fit within the OE 18" touring and Track model wheels.
Rears- 4-piston aluminum alloy calipers with high-performance, 2-piece 330mm (13") cross-drilled and slotted rotors that are 26mm thick for optimum heat capacity. The rotor core uses a racing-derived curved vane design for maximum cooling and is mounted on a steel hat that incorporates a parking brake surface. The caliper is attached to the OE knuckle with a heavy duty steel or high-strength aluminum bracket and Grade 8 or better hardware. DOT-compliant stainless steel brake lines and all necessary hardware are included, so this kit is ready to bolt on and is fully compatible with OE parking brake components. This kit will also fit within the OE 18" touring and Track model wheels.
Price- 3900.00
***Note, the Calipers are BLACK in color***
Please let me know if you have any questions.
Old Oct 25, 2006 | 02:00 PM
The Calipers are BLACK in color not RED. Please let me know if you have any questins or need pics.
Old Oct 30, 2006 | 11:26 AM
***Bump***
Old Nov 13, 2006 | 04:35 PM
ttrank's Avatar
Grocery getter
Willing to sell just the rears?
Old Nov 16, 2006 | 10:09 AM
I can not part this kit out at this time.
Old Nov 21, 2006 | 06:55 PM
mbdizzle's Avatar
Thumbs down
ttrank, i'm willing to buy just the fronts, if u want to combine and purchase the entire set. let me know. 3900 is
Old Sep 12, 2007 | 09:10 PM
OH6 G35's Avatar
Are these still available ?? If so, where are you located ?
thanks...
Old Sep 13, 2007 | 03:06 PM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
thanks...
AAM is in Gaithersburg, MD. I think these are long gone since this was about a year ago. They had offered them to me last year when I was having some service done and I just did not have the cash at that time. Very good shop, you should just call them.
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
emorehs
Jul 17, 2015 09:45 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
