CZP Stock Sized Brake Kits, Brembo Kits now available >>
Old May 31, 2007 | 02:53 AM
Coz@Czp's Avatar
CZP Rotors:
__________________________________________
Non-Brembo: $625 Shipped
Brembo: $700 Shipped
Description:CZP Brake Kit - Front & Rear Rotors, Front & Rear Hawk HPS Pads, Front & Rear Stainless Steel Brake Lines, and ATE Super Blue Dot 4 Brake Fluid. These kits are stock sized replacements rotors, they are not bigger then stock, because if they were, you would need new calipers to fit bigger rotors.
We only use Centric Rotors(Stoptech Brand), but instead of using a black coat, we Zinc plate them for a cleaner look. The combination of cross-drilled and slotted will give you the best of both worlds. It will dissipate heat and increase bite for better stopping power.
These Rotors are:
Military spec. Plating
Prevent premature warping
Prevent fade
Reduce operating temperature
Reduce stopping distance
Pads:
Hawk Performance HPS compound provides advanced braking characteristics to enhance your driving experience. This unique compound combines the safety and quality of Aerospace design partnered with the braking technology of motorsports.
Features -Extremely low dust
-High friction/torque hot or cold
-Gentle on rotors
-Virtually noise-free
-Much improved braking over OEM
-Long extended pad life
Technafit SS Lines:
Stainless Steel Brake Lines provide a quicker pedal response, maintaining consistent brake pressure and precision brake modulation, especially during threshold braking.
ATE Super Blue Brake Fluid:
ATE Super Blue Racing brake fluid has a dry boiling point of over 530 degrees F, far exceeding DOT 4 standards. Mixes with any other DOT 3 or DOT 4 fluid. Super Blue absorbs moisture very slowly, so you don't have to change it as often as many high-performance fluids. Great for your street car that sees weekend track duty.
Old Jun 29, 2007 | 09:17 PM
cooldog45's Avatar
how much for the kit without the lines? shipped to 07002
Old Jun 29, 2007 | 10:10 PM
gsRt5's Avatar
Same here but to 78228?
Old Jun 29, 2007 | 10:34 PM
johnsonhuang's Avatar
how big are these things?
Old Jul 8, 2007 | 12:04 AM
gsRt5's Avatar
Still no reply?
Old Jul 10, 2007 | 03:41 AM
Coz@Czp's Avatar
Knock off $60 w/o the lines.
Coz
Old Jul 10, 2007 | 03:42 AM
Coz@Czp's Avatar
$60 less w/o the lines.
Coz
Old Jul 10, 2007 | 03:43 AM
Coz@Czp's Avatar
How big are stock sized replacement rotors? This is not a big Brake kit, these are stock sized, so fit directly under your stock caliper.
Coz
Old Oct 29, 2007 | 01:54 AM
Coz@Czp's Avatar
Bump
Old Aug 2, 2008 | 03:35 AM
Coz@Czp's Avatar
bump
Old Nov 27, 2008 | 12:04 AM
Inspired's Avatar
how much for the front and rear rotors only, shipped to QC, Laval h7w 1g9
marsman328
Northern California
Aug 11, 2015 07:29 PM
Popes
Jul 29, 2015 05:07 PM
Karnicle
Jul 23, 2015 05:08 AM
realtalk21
Jul 20, 2015 09:07 AM
