Brake Upgrade Package - OEM Size
Old Aug 22, 2008 | 07:53 AM
ARTrace's Avatar
Arrow Brake Upgrade Package - OEM Size
Front and Rear Powerslot slotted Rotors
Hawk Pads
Russell Brake Lines
$625.00 Shipped if you use Google checkout in our store
Excessive heat can cause resins in your brake pad to vaporize or "outgas." As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surfaces and inhibits performance. Here's where Power Slot's slotted brake rotors make a big difference.
Power Slot's exclusive Vac-U-Slots are machined into the rotor and help evacuate gasses and dust, shed heat, and keep the brake pad surface clean. And in wet, raining conditions, our Vac-U-Slot helps push water off the braking surface for better stopping power.
The Vac-U-Slot also serves as a visual wear indicator. The slot is machined to the rotor’s minimum thickness where it crosses the outside edge. If you cannot see the slot along the outside edge, the rotor has worn down to its discard depth.
A combination of Hawk® high performance brake pads and Power Slot
slotted rotors will deliver superior, reliable braking for virtually
all automotive, truck and SUV applications, even under hard
driving and severe duty conditions. But for our most
demanding customers such as police pursuit vehicles
and club racers, we also suggest Power Slot Cryo rotors.
Old Aug 23, 2008 | 04:27 PM
ARTrace's Avatar
bump
Old Aug 25, 2008 | 07:22 AM
ARTrace's Avatar
- free shipping today only- Monday 8/25/08
Old Aug 26, 2008 | 07:14 AM
ARTrace's Avatar
bump
Old Aug 27, 2008 | 07:21 AM
ARTrace's Avatar
mmmmmmmmmmm
Old Aug 28, 2008 | 08:37 AM
ARTrace's Avatar
nnnnnnnnnnnn
Old Sep 3, 2008 | 09:13 AM
ARTrace's Avatar
bump
Old Sep 5, 2008 | 10:15 AM
ARTrace's Avatar
bbbbbbbbbb
Old Sep 12, 2008 | 09:40 AM
ARTrace's Avatar
nnnnnnnnnnnnn
Old Sep 16, 2008 | 10:40 AM
ARTrace's Avatar
vvvvvvvvvvvvvvvvvvv
Old Sep 17, 2008 | 10:17 AM
Sandy@ART's Avatar
ttt
Old Sep 24, 2008 | 08:45 AM
ARTrace's Avatar
bump
Old Sep 27, 2008 | 08:40 PM
Mike@ART's Avatar
ttt
Old Sep 28, 2008 | 06:49 PM
Sandy@ART's Avatar
ttt
Old Oct 1, 2008 | 12:23 PM
Sandy@ART's Avatar
to da top!!
