Infiniti Akebono 14" Brake Kits for 07+ G35/G37 Sedan, 08+ G37 Coupe
#91
CoZ- wanted to get your take on the correct orientation for installing the plate bracket- FSM calls for it one way, folks here are doing it the opposite as well.
Thanks!
https://g35driver.com/forums/brakes-...-07-g-z-3.html
Thanks!
#92
Thanks!
Thanks!
#93
2 more questions for you- with the HPS pads- would you recommend keeping the Hawk shims or using the OEMs? Looks like the OEMs would fit just as well. Plus, the rears have the two-part OEM shims.
Also, looks like the StopTech drilled+slotted rotors are labeled such that the slots sweep brake junk inwards toward the hub- so the slots "lead" at the outer edge of the rotor- wanted to make sure this made sense.
Thanks again
Thanks again
#96
#98
#100
#102
#104
#105
