FS: New! Front Blank Rotors - Centric (Lansdale, PA)
I'm selling my brand new, never installed front rotors because I have sold my 2003 G35 sedan. Asking $100 for both and prefer local pickup, but will ship at buyer's expense.
Part number: 120.42080 - Please make sure you check out the manufacturer site for fitment: http://www.centricparts.com/
All Centric premium brake components are engineered and manufactured using stringent, well-proven production processes and parts that pass the stringent quality assurance standards of O.E. manufacturers as well. Additionally, Centric's in-house engineering department analyzes each part to ensure proper performance and fitment for every application (import and domestic). This attention to detail guarantees that Centric parts will perform as good as or better than the factory original.
Centric Premium Plain 120 Series Rotors feature an Electrocoating (E-coating) finish that provides long lasting corrosion protection. Unlike phosphate finishes that provide only minimal protection from the elements, E-coating is a superior electrostatically applied finish designed to withstand 400 hours of salt water exposure without rusting.
Double Disc Ground
Centric Premium Plain 120 Series Rotors are double disc ground with a taper-free finish. Double disc grinding ensures parallelism, eliminates run out and provides near perfect disc thickness variation (DTV). Double disc grinding leaves a non-directional finish on the friction surface area for more effective pad-rotor break in.
Machined Finishes
Centric Premium Plain 120 Series Rotors feature 100% fully machined finishes including rotor hats. This extra process provides better rotor balance and creates a cleaner, more finished looking component. Additionally, all Centric rotors are inspected for balance and mill-corrected to a tolerance of less than 2 oz. per inch
Split Castings
Center-split core castings provide proper heat transfer and thermal efficiency, resulting in superior braking power and safety.
Mill Balancing
Centric Premium Plain 120 Series Rotors are mill-balanced to a tolerance of less than 2 oz. per inch. This additional machining operation reduces the feedback associated with rotor vibration and provides a smooth, confident application of braking force.
Double Disc Ground
Machined Finishes
Split Castings
Mill Balancing
These will fit 2003-2004 years. Manufacturer says this part number will fit the 05 AWD as well, but I'd call them to verify.
^ Before you put your 2cents in, how about you do some research first. According to the manufacturer, these will fit '05 as well. Anyone interested, please check for fitment on their site first: http://www.centricparts.com
The part number is clearly provided, so buyers are responsible for making sure these will fit their car.
P.S. Centric lists these two part numbers for '05 Fronts: 120.42074 AWD , and 120.42080 for RWD. They are only listing part# 120.42080 for 2006 , which is interesting.
Jiggerjuice
Aug 17, 2015 08:41 AM
