Buying, Selling & Leasing Discussion Interested in getting a G35? Ask your questions here! (No Classified Posts)
Things to look out for when purchasing a G.
Old Jul 2, 2013 | 01:56 AM
Invalid_User's Avatar
Suspension noise that usually is due to the notorious Compression Rod bushings or Lower balljoints.
Cracking in Dash
Tears in Seat
OC issue rare in AT but they are out there.
Valve cover gasket (check spark plugs to see if there is any sign of oil, if there is then valve cover gaskets need replaced)
Radio is a hit or miss, I have 100k on mine with OEM radio still working.
Do yourself a favor and get an 05+
I really suggest you get an 06 since they come with projectors and upgraded goodies along with most issues being fixed from previous years.
Old Jul 2, 2013 | 06:18 PM
Limitless's Avatar
Originally Posted by JKL1031
marked oil pan shows that the car was put on an OC test. this can be taken either way if the mark is there and the same engine is still there, it may have passed the test. but the mark is there in the first place because someone must have complained about losing oil. try to keep the car idling while you talking and blip it and watch for smoke. most cars that smoke smoke off idle. Longer idle the better.
Any dealer should have a lift. Tell them you want to look under, should be no problem.
Thanks for the reply JKL, so I guess it's a good thing if the oil pan is marked. Will it be an obvious mark?
I'm not exactly sure what blip means? Thanks!
Old Jul 3, 2013 | 12:50 AM
JKL1031's Avatar
I cant say a marked pan is good or bad. A lot of people had hard times getting a replacement engine and convinced nothing was wrong. It should be yellow, blue, white, or any color really around the drain bolt. blip is a quick mash of the throttle.
Old Jul 3, 2013 | 08:29 PM
Limitless's Avatar
Thanks JKL, I guess I shouldn't have to worry too much about to OC issue since I'll be getting an Auto (I know but I hate driving MT during traffic).
Old Jul 5, 2013 | 07:07 PM
Almightyone's Avatar
If you can do a compression check on the motor without having to go out of pocket too much it might help with trying to see if the car has an OC issue. Not really realistic but it could help make the decision if the car is worth it or not. I know with it being a auto you have less chance of it but better safe than sorry.
jsimonk
Dec 22, 2023 03:49 PM
yosip1115
Forced Induction
Jan 28, 2016 02:51 PM
miata007
Aug 17, 2015 04:36 PM
Karnicle
Jul 23, 2015 05:08 AM
