Canada Serving Canada.
New Hawk Pads Squealing
Old Jun 6, 2006 | 10:19 AM
kamikazeiG35's Avatar
Sorry for hijacking this thread
What about if I'm getting that squeak thing only when I'm nearly stopped (1-2km/h) with STOCK brembos on? I notice it mainly coming to a complete stop at red lights and pulling into my garage.
I just had my 24K milestone check up done and I have over 60% of my pads left (so I know its not worn down).
I'm just wondering if this is a common thing with an easy solution.
Thanks,
Al
Old Jun 6, 2006 | 10:32 AM
Jasonoff's Avatar
There's 2 types of squeak.
There is the pad compound friction squeak/squeel (you can not fix this)
And there is the pad shift resonation squeak that you can either eliminate or reduce with the use of brake quiet goop.
Old Jun 6, 2006 | 11:23 AM
Balzz's Avatar
Brake quiet also in the right places also aid in prevention of squealing from Jasonoff.
Old Jun 6, 2006 | 11:24 AM
Jasonoff's Avatar
I'll even install it for you
Old Jun 6, 2006 | 01:37 PM
kimro's Avatar
I got Hawk ceremic pads and mine don't squeek at all.. not sure of the model number tho..
Old Jun 6, 2006 | 03:04 PM
noodleman's Avatar
mine didn't squeek at all in the beginning, it's recently that it's started squeeking once in a LOONG while (like twice that i remember since i installed them)...
I love the low dusting these pads have though compared to the stock pads...i'd have a headache and a half trying to keep my volks clean if i was still running stock pads.
Old Jun 7, 2006 | 07:04 PM
G-Force's Avatar
Crappy tire. Get the permatex stuff. Did you bed them in properly?
UPDATE : Put on the Permatex Brake Quiet lube yesterday. Well it was pretty hot coming home so I really slammed the brakes a few times to make sure they were good and hot etc. No squealing at all, thank Balzz great suggestion, worked to a T. I will keep an ear open but they seem silent for now.
Old Jun 8, 2006 | 03:19 AM
godmans's Avatar
How about if I am squealing with stock pads?.. even tho I came from a brake service about a month ago..
Oakville made me do the rotors turning stuff instead of giving me new rotors ..and it costed me around $250 to do the whole thing
Old Jun 8, 2006 | 08:09 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Yah, but I heard that stuff melts the pads if it gets wet.
Old Jun 9, 2006 | 06:30 PM
Gordgee's Avatar
Administrator
Originally Posted by k_hojnacki
hmm interesting. I replaced both rotors and pads (front and rear) at the same time and also use the Hawk HPS pads. I have no squeak at all after following the procedure to the letter. BUT I also used the factor anti-squeak shims from my old pads on top of the Hawks. 10,000+ miles no squeak, very little break dust and they are wearing like iron and stopping has been incredibly improved.
Same experience here.
Absolutely no squeal, and dusting of the front pads is virtually identical to the rears, ie. minimal.
I did the bedding procedure as stated on the box right after installation, and the Permatex Goop was literally boiling on the pad!
No braking problems hot or cold (as some have mentioned elsewhere).
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
