Canada Serving Canada.
Article on new G35 Sedan HP
Old Aug 20, 2006 | 04:28 PM
MidnightBlue's Avatar
Check out this article from msn...
http://news.en.autos.sympatico.msn.c...umentid=722295
Old Aug 20, 2006 | 04:34 PM
shellguy05's Avatar
Damn the sedan is more powerful than the coupe, they are going to be flying right by us coupe drivers. lol. still such a beautiful car.
Old Aug 20, 2006 | 05:20 PM
Garnet Canuck's Avatar
Traveling Administrator
Good find.
I find it interesting that they state the IS350 might have the advantage over the new G35 because of its 6 speed automatic. I think that any advantage the IS350 has from its 6 speed auto is nullified due to their lack of a manual tranny option.
Old Aug 20, 2006 | 05:54 PM
Msedanman's Avatar
O.F. Administrator
Good find MB.....that ride will be real special.....
306 ponies is very impressive......I expect the new coupe in '08 will get a 'bump' in hp too.
Infinitis are going to be even more impressive in the near future.
C.
Old Aug 20, 2006 | 06:10 PM
RBull's Avatar
Rated M
Yeah good find, confirming what we already know.
From what others are saying that have driven it the Lexus is not in the game from a chassis/handling perspective. One thing I noted is the author did not make reference to the 335 coming very soon.
It will be interesting to see what the Coupe will have as a powerplant. Infiniti will likely be tight lipped about that as well.
Old Aug 20, 2006 | 07:15 PM
Picus's Avatar
Staff ALUMNI
I dunno about the auto thing with the IS350 - that is one fast AT; way faster than the Infiniti 5AT. I still think both the IS350 and 335i will be faster; Infiniti is going to have to bank on handling better than the IS (which should be easy) and being priced ~$5+k less than the 335i (which also should be easy).
The thing I wonder most about is what the confirmed torque of the new G35 will be. If they had to reduce tq into the 260/270 range to get 306hp...well...ya.
Old Aug 20, 2006 | 07:22 PM
I guess I was just speaking from a customer buying perspective rather than a performance one.
Old Aug 20, 2006 | 08:37 PM
Picus's Avatar
Staff ALUMNI
Oh ya, definitely. It wigs me out that the IS350 isn't even offered in a MT, but frankly I personally don't see the IS's as competition to the G35/335i. I know that's probably an unpopular view, but having driven the IS350 a few times now as fast as it is it feels way too soft and clumsy to me, even with the VDIM disable trick.
Old Aug 20, 2006 | 08:49 PM
RBull's Avatar
Rated M
Kevin, the IS is somewhat faster than the outgoing G sedan. I believe the addition of another 31 SAE horsepower in the '07 G with the same relative weight may make it a closer showdown regardless of tranny. However, it's highly doubtful either of these will match the new 335.
We can pretty well guarantee the G will run circles around the IS in the handling department. It's most likely you're right about the significant price point difference between the G and the 335. I think torque for the new G sedan has been confirmed at 270.
Old Aug 20, 2006 | 09:46 PM
Balzz's Avatar
Means nothing without knowing the weight of the new car.
Old Aug 20, 2006 | 11:37 PM
Picus's Avatar
Staff ALUMNI
http://www.caranddriver.com/cartrims...g35_sedan.html
Old Aug 21, 2006 | 12:20 AM
codeflux's Avatar
IS350 will still come out on top... an extra gear does it...
but, after all, only the real world test will tell for sure. i want real life 1/4 runs.
Old Aug 21, 2006 | 07:46 AM
07 Sedan......................................05 Sedan
Front headroom w/o sunroof 40.5".......40.1"
Front headroom w/ sunroof is 39.1"......38.7"
Rear headroom w/o sunroof is 37.7"......37.9"
Rear headroom w/ sunroof is 37.2"........37.4"
Front shoulder room is 55.6"................56.4"
Rear shoulder room is 55.2"..................55.5"
Front hip room is 55.1"........................52.2"
Rear hip room is 53.7".........................54.1"
Front leg room is 43.9"........................43.6"
Rear leg room is 34.7".........................33.6"
Cargo capacity is 14 cubic feet............14.8 cubic feet
Curb weights-07 Sedan....................05 Sedan
G35 2wd is 3498 lbs............................3482 lbs
G35x is 3703 lbs.................................3668 lbs
G35 Sport 6MT is 3532 lbs....................3516 lbs (Aero package 6MT)
Old Aug 21, 2006 | 07:51 AM
RBull's Avatar
Rated M
^ thanks for saving me the search.
Old Aug 21, 2006 | 10:37 AM
Picus's Avatar
Staff ALUMNI
They put on under 20lbs with the base and sport models? Damn, gotta give it up to Infiniti on that; they gained room, tech, engine power, dual exhaust, and didn't give up weight. Can't say the same for the porky IS350 or 335i that's for sure. Both cars are significantly smaller and weight the same or more.
