Canada Serving Canada.
AAM tuning day.
Old Nov 20, 2006 | 02:41 PM
Mike@Altered's Avatar
Hi Brian,
The ECU Flash will help tie everything together and allow your engine to have the proper fuel & timing for bolt-ons. The ECU Flash between the different bolt-ons is very similar, the only NA upgrade that would use a different program are camshafts.
Once you have the AAM ECU Flash, upgrading to a different program typically only costs $195.00 - so you do not have to spend $595 each time
Here is another set of high-flow cats that works exceptionally well on the G35: http://www.alteredatmosphere.com/mm5..._Code=350Z_EXH
These are the best flowing high-flows for the 350Z & G35 becasue they are a true 2.5" stainless and use Metallic eliments which flow much better than the traditional Ceramic cats most people use.
Let us know if you have any other questions.
Hope this helps,
Old Nov 20, 2006 | 11:34 PM
godmans's Avatar
Thanks for the tuning Mike!
Old Nov 22, 2006 | 09:39 PM
Oggie's Avatar
Godmans, I was out of town when this thing happened. How does you can feel now compare to before? From dyno numbers to seat-of-your-pants feel.
Old Nov 22, 2006 | 09:56 PM
godmans's Avatar
I picked up sth like 17 whp and 20 ft lbs of torque.
The gain is very noticeable up top (above 4.5k rpm) where the car used to die out very quickly; whereas the top end pull now is incredible.
KruZZe
Feb 27, 2023 05:04 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
