Winter tires now? or later?
I am trying to guage when I should change my summers to winters. Someone told me I should change them when the temperature is below 10C since there is no traction on summer tires at that temp. Is that outside air temperature or ground temperature? Or should I wait until first snow fall and then change them?
Eeyore
Eeyore
Thanks Wayne.... I was looking for a consensus to some intuition I had. So I am bringing out my cordless 3KO drill, the jack and blocks and doing on the drive way. Oh by the way any idea on proper placement of the jack to lift the car. The manual shows the spot, but when I look at it from the last time I changed the tires, they were pushed in from the weight of the car. So I am wondering where is a good place?
Kariim.
P.S. tire pressure for winter tires should be the same pressure as stated on the door right?
Kariim.
Kariim.
Kariim.
Winter tire pressure should be about the same as your summer pressure. A bit of tweaking of air-pressure, summer or winter, can be done depending on your preference and wear patterns on the tread.
Eeyore
Eeyore
Don't wait any more. You need them on b4 we get much snow or cold.
C.
Originally Posted by Gordgee
You should be using an adapter or flat, grooved rubber saddle for your floor jack if you are using one to lift from the sides of the car to avoid crushing the rails.
Crap! Had I have known that I would have done something about it. Can I purchase one of these adapters or do I need to manufacture one. I have a 1/2 jack that has a grooved crown, and I think that should be okay.
Karim.
Ran into a snag. I can't seem to find the bolt size for the bolts on the car. Does anyone know what the correct size is? I am wondering if it is 22mm?
Thanks
E.
Thanks
E.
Thanks
E.
Thanks
E.
Wayne
Originally Posted by GEE35X
Karim, If you are talking about the socket size to remove the lug nuts, you need a 21mm socket. The torque for your lug nuts when you re-install should be 80 ft-lbs.
Wayne
Wayne
80 ft-lbs!! DAM!! I can bearly make 10 with my weakling arms!!
Karim
Thanks Wayne, you are a life saver!!
Karim
Karim
You won't have any problem tightening them up to spec. Actually a lot of guys overtighten them, thats why its a good idea to invest in a 1/2" drive torque wrench.
