fuel injection cleaning?
I've had mine out when I did the fuel system. It's not that hard if you are mechanically inclined. You will probably want to replace the o-rings on the injectors at the same time. If I remember right there are three per injector. Remember that the fuel is pressurized so when you take them out the fuel is going to spray unless you relieve the pressure somehow, usually be letting the car sit for awhile without turning on the key.
Originally Posted by ttrank
The best cleaner I have found is BG K44 cleaner. It's about $20 a can but works better than anything I have ever found. I run a can every 10k.
tia
C.
Mad A
Not G35 Related
12-08-2015 01:45 PM
Rhinos7777
09-06-2015 05:36 PM
