Canada Serving Canada.
Tire Sizes
Old Jan 15, 2007 | 07:27 PM
alphabit's Avatar
Tire Sizes
I know I could have used the search button, but there are too many posts to read through.
I current have 19 x 8.5 F and 19 x 9.5 R. Are there any advantages or disadvantages in running (245/35 and 275/35) opposed to (245/40 and 275/35).
Thanks in advance.
Old Jan 15, 2007 | 08:34 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
You want to stay as close as possible to OEM diameter(s) as possible.
The VDC uses these sizes in the algorithm that detects slip.
That said you can vary slightly w/o compromising the system.
I always play with the size calculators to get the optimum size.
Calculator
Old Jan 15, 2007 | 09:31 PM
GEE35FX's Avatar
Here's another good one http://www.canadiandriver.com/tools/...c/tirecalc.htm
Old Jan 15, 2007 | 10:39 PM
Picus's Avatar
Staff ALUMNI
The only disadvantage in that setup, aside from the slightly smaller front diameter, is looks. Generally the rears are one profile size lower than the fronts.
Old Jan 16, 2007 | 01:10 AM
alphabit's Avatar
So 245/35 and 275/35 should be ok? The reason I am asking is when I called my tire shop they suggested going 245/40 and 275/35.
Thanks
Old Jan 16, 2007 | 09:53 AM
Picus's Avatar
Staff ALUMNI
Ya, it will be ok. Most guys just go with one profile size higher in the front. Like for example my car is 225/40 and 255/35.
Old Jan 16, 2007 | 01:26 PM
lowrider's Avatar
245/40/19 in front would be an incorrect size to run with the 275/35/19 on the rear. The 245/40 would be the same height as the 275/35 tire in the back. Your tire shop recommended this because they do not understand the stagger designed into the "G" or "Z" and many other sports cars. Stay with the 245/35/19 and 275/35/19 combo with your 8.5 and 9.5" wheels. It's Correct.
Oh Oh. Do you have a Coupe? I just realized you MAY have a Sedan. If that's the case, forget everything everything I just said.
Lou
Old Jan 16, 2007 | 01:42 PM
InTgr8r's Avatar
Lou
alphabit = coupe
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
