Canada Serving Canada.
sandbags in the trunk for snow traction
Old Dec 13, 2003 | 12:26 AM
Tabz's Avatar
other than winter tires and careful driving i've heard that putting weight, like a 50 lb sandbag in the trunk will help with traction issues in the snow for powerful rear wheel drive cars like ours. Can anyone comment?
03 G35 coupe SS (GD) 6spd everything but navi, borla exhaust
02 QX4 pearl white
00 528 Silver on black
Old Dec 13, 2003 | 01:55 AM
Saridi's Avatar
Re: sandbags in the trunk for snow traction
I heard that and tried that on my previous car as well....and the result aren't impressive to me, and seems more oversteer when doing cornering. Actually, once our cars got a set of good snow tires and make sure VDC is on, then that should be enough for our normal winter driving.
Grounding Kit
GruppeM Intake (ETA: No idea.... [img]/w3timages/icons/frown.gif[/img])
Fujitsubo Cat-back + Y-pipe (On order)
19" NISMO LM GT4 (On order)
Old Dec 13, 2003 | 11:14 PM
Gordgee's Avatar
Administrator
I usually keep about 100lbs of sand in the trunk. It can be helpful starting out from a dead stop in very low traction conditions, like on an incline. Conversely, the extra weight can change the handling balance of the car and the extra mass can make it a little slower to come to a stop.
<font color=green>GG</font color=green>
Old Dec 15, 2003 | 01:19 AM
duhprez's Avatar
Easier to just keeping your gas tank full.
G35 Coupe 6MT Brilliant Silver
Tinted Windows
7 -Wire Hyper Ground System
Complete Front-end Clear Bra
Old Jan 17, 2004 | 10:17 PM
derek's Avatar
From: Metropolitan South Farmington, not too far from the supercity we all know as Wilmot, NS
Sand bad idea, fuel as suggested- good idea. And good winter tires. If you must use the sand, which will turn your car into a big pendulum if you're not careful, recommend having it between the axles- further forward the better. The fuel of course, by design, will be well placed, and as an added bonus, you won't get water in your fuel lines from condensation in the tank.
Cheers,
D
DB
g.spot
May 9, 2016 10:54 PM
markbilo
Sep 30, 2015 01:33 AM
TurTLe*
Sep 29, 2015 01:43 PM
vamarris
Sep 26, 2015 12:56 PM
