Canada Serving Canada.
A funny and a not-so-funny
Old Mar 27, 2007 | 12:21 AM
Christian's Avatar
Originally Posted by BMC
Oh well, I'm off to a tire shop tomorrow morning to get the valve stem replaced. I'll ask them to their own check of the tire and wheel but I'm sure I found the cause of the leak....I hope!
I guess you haven't seen the heavy snow warning for Calgary for tomorrow morning 15-17cm of the white stuff is expected
Old Mar 27, 2007 | 12:41 AM
BMC's Avatar
BMC
Yup. I'm very aware of the heavy snow warning. My Z stays in the garage when it snows. I use my wife's RAV4 as my daily driver, while she, being the mother of my soon-to-arrive child and needing the room for the infant car seat and other baby gear, gets to drive the Pathfinder (even though I'd have more fun driving it!).
I simply took the leaking tire/wheel off my Z and will throw it in the backseat of the RAV and it's off to the tire shop. I still have my OEM 18's so I put one on the right front corner of my Z so that it doesn't have to stay jacked up while the tire is brought to the shop.
So there's no need for my Z to fight for its dear life in the coming snowstorm. It'll be safe and sound.
Old Mar 27, 2007 | 08:03 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Oh man... keep that crap out there!!!!!
- I'm PO'd today cause I needed my truck @ work...... 21deg & sunny this afternoon.
Old Mar 27, 2007 | 10:37 AM
BMC's Avatar
BMC
21 C ! I am jealous! The snow flakes are coming down as I type this they expect it to subside mid-afternoon. Yeesh.
Old Mar 27, 2007 | 11:27 AM
RBull's Avatar
Rated M
Yeah, you had some weather the other day. We're pretty much still waiting for the real break through too.
Old Mar 27, 2007 | 02:24 PM
Msedanman's Avatar
O.F. Administrator
LOL, Ian.......TRUCKIN' in the sun????????-- not good...you better fix that in a hurry....
C.
Old Mar 27, 2007 | 05:03 PM
InTgr8r's Avatar
C.
DONE DEAL... I headed home early for a little top down fix
Old Mar 27, 2007 | 07:17 PM
whatacar's Avatar
I'm not usually envious, but in your case I'll make a short exception.......there, it's over.
Old Mar 27, 2007 | 07:23 PM
Hi-TechG35's Avatar
Dude change the tire just for safety!
Old Mar 27, 2007 | 10:07 PM
BMC's Avatar
BMC
Thanks for your concern, but I'm pretty confident it's not the tire. I've already determined via the soap/water trick that the valve stem is a definite cause for a leak. Could there be additional causes over and above that? Of course. But that's why I'm taking it in to have it looked at by the pros.
And sure, it's plausible that there could be a defect in what is a brand new tire (I've only put a little north of 200 km on it), but based on what I've seen it's the valve stem. I didn't have time to take it to the shop for inspection today, but I'll do so tomorrow.
Old Mar 27, 2007 | 10:15 PM
kraqcommando's Avatar
nitrogen hmmmm?
Old Mar 28, 2007 | 03:57 PM
BMC's Avatar
BMC
Originally Posted by kraqcommando
nitrogen hmmmm?
Krac-kerJack - the tire was originally filled with nitrogen. The tire is not the issue.
*** UPDATE
Just got back from the tire shop - they confirmed that it was the valve stem that was the issue. There is a grommet and a hex bolt that attaches the stem to the wheel. The grommet and bolt were loose, so they tightened it with needle nose pliers, and then applied silicone on the inside of the wheel to promote a tighter seal. I just have to monitor the stem in case it ever gets loose, but otherwise it looks like I'm all set. It was actually good that they were able to do a fix buy tightening and sealing with silicone, bc usually they just replace the valve stem altogether - however, they couldn't find any matching metal aftermarket valve stems that matched the one on the Super Rozza. So now, instead of having one valve stem that doesn't match the others, they will all look the same.
I guess the true test will be to throw the wheel back on the Z, go for another run and see if it deflates again.
Side story - When I brought it in, I put it in a plastic tire bag and covered the good side of the wheel with a flat piece of cardboard.
When I came to pick it up, one of the guys rolled out my wheel from the service area. It wasn't initially in the bag, but then he put it in the the plastic bag and slid the cardboard in. So, he then leaves the tire now standing on the floor on its contact patch (i.e. not flat on the ground). Lucky for me he put the cardboard in - coz before I could walk over to the tire to lay it flat on the floor on its inside face, sure enough the other guy who was ringing up my invoice proceeds to turn around and accidentally KNOCKS OVER MY WHEEL FACE FIRST. Oh man, I was about to kill someone. Fortunately when I picked up the wheel and checked it out, the only minor scratches that were there present on the lip were the ones that existed when I brought it in. If the wheel had been badly scuffed as a result of that fall, I would have blood on my hands! The cardboard saved the wheel from certain damage.
One thing's for sure, I'll be glad once all of this BS is over and my wheel is back on the Z. Sheesh.
Old Mar 28, 2007 | 04:44 PM
RBull's Avatar
Rated M
^ good to hear Joel, especially the part about the cardboard saving the wheel
Old Mar 28, 2007 | 05:00 PM
Msedanman's Avatar
O.F. Administrator
Glad it all worked out for you Joel....and that it was as you suspected...the valve stem.....
(yeah, good thing for cardboard.... )
Colin.
Jeff469
Sep 25, 2015 09:28 AM
PrestigeG35
Sep 21, 2015 10:10 AM
Nickles
Sep 1, 2015 08:11 PM
derres
Aug 28, 2015 03:27 PM
j_mullet
Aug 26, 2015 10:49 PM
