Canada Serving Canada.
Any Canadian try swapping in 06 Headlights???
Old Jun 5, 2007 | 12:58 AM
netcbc's Avatar
How is the wiring, is it hard to get DRL to run? Is it true we can just use the stock ballast plug and play?
Old Jun 5, 2007 | 01:02 AM
akachi's Avatar
yes you use your stock ballast, plug and play
Old Jun 5, 2007 | 01:05 AM
j.le's Avatar
refer to this thread
https://g35driver.com/forums/canada/90795-2006-light-housing-2005-earlier-models.html
Old Jun 5, 2007 | 01:43 AM
netcbc's Avatar
Thanks that is quite helpful but at the same time kinda dont' know what to do, lol, there's no way I can wire it myself and I'm assuming it would costly, guess have to stick to my non-projectors
Old Jan 24, 2008 | 12:00 PM
specialist's Avatar
why would you need to do the wiring with relays if you just use your old wiring from a 03 g35 car?
Old Jan 24, 2008 | 01:22 PM
alphabit's Avatar
You can try calling Jeff at http://lockdownsecurity.ca. I was going to get my lights done there, but the deal for the lights fell through. He is the one who installed my alarm.
Peter
Old Jan 24, 2008 | 01:36 PM
Adon's Avatar
just PLUG THEM IN! case closed.. I was in the same situation as you, running around like a chicken with my head cutoff trying to figure out the deal. Thinking the whole time the lightbulbs would blow up, or I would blow a fuse or worse.... Until for kicks I just decided to plug them in and give them a go, it works perfectly fine, except that you have to manually turn the lights on yourself. This is something I dont mind myself since I have blacked out housings and in the daytime with my lights off the front of my car looks mean all blacked out. Only other minor problem I have is my turn signals, when i dont have my lights on and I signal left or right, most of the time my turn signal hyper flashes, it blinks really fast, but that has nothing to do with the wiring itself, it's just one of the bulbs I went with, it's suckin up more voltage than it's supposed too.. so yea my advice, PLUG THEM INTO YOUR BALLASTS dont waste anymore time
Hey j.le we're having a meet on G35.ca by the way, check this thread and sign up here http://www.g35.ca/board/index.php?showtopic=6870
Old Jan 24, 2008 | 03:20 PM
Finiti's Avatar
There is a wiring diagram floating around here to fix the signal light issue. That's all I did to my housings. Not having DRl is not a big issue for me.
alessandro
Oct 8, 2015 09:29 AM
Moskvitch
Sep 14, 2015 10:15 AM
DG2Door
Sep 11, 2015 08:04 PM
mtlruss
Lighting
Sep 9, 2015 07:44 PM
