Canada Serving Canada.
Ottawa service shop recommendations
Old Mar 3, 2008 | 08:43 PM
SmoothieG35's Avatar
Question Ottawa service shop recommendations
I'm looking for a garage that you would suggest I brig my 03 coupe to. I'm needing some basic maintenance done in the near future. Likely fluid changes and brake pads all around.
Where in Ottawa would you suggest, besides the stealership of course. These are slightly outside my comfort level of doing it myself, plus I'm lazy :P.
Old Mar 5, 2008 | 12:17 PM
elrooko's Avatar
Do it yourself man!!! I live in Ottawa as well and haven't found any good ones so far. 417 is hit or miss. I have had good and terrible service with them so I avoid them if I can. If you need help doing the basics yourself stop by (I'm in Orleans) and I can show you what little I have been able to do.
So far the list of DIY's I have successfully completed
ZTube
Air Filter
InCabin Microfilter
Oil & Filter Changes
Spark plug change
Tranny and DIFF fluid changes
Brake pad and rotor replacement
Brake fluid flush, fill and bleed
Sway bar install
Rogue Short Shifter Install
Full Exhaust install
5/16 Plenum spacer
ISO Thermal gasket install
Throttle Body Heater install
Front Upper Strut bar
This is starting from basically no mechanical knowledge before I bought the car 4.5 years ago. My only really knowledge was how to fork over money to the dealer and have them steal it from me . G35Driver will teach you basically everything you need - it did for me.
Old Mar 28, 2008 | 09:01 AM
Madelinot's Avatar
I agree, try to do it yourself. It's quite rewarding and will save you a bunch of money. I do most of the stuff myself, I will even tackle swapping my engine in the next few months.
Old Mar 28, 2008 | 11:20 PM
whatacar's Avatar
Good for you ++. I'm gonna try doing the oil in the summer and maybe more.
After watching my brakes being done and a grounding kit installed I bought myself a set of (4) stands and a pump jack. Both are still in the boxes.
BTW what are you swapping your engine for?
Old Mar 29, 2008 | 05:24 AM
The-Dream's Avatar
ZTube
Air Filter
InCabin Microfilter
Spark plug change
Sway bar install
5/16 Plenum spacer
Have we randomly met on the highway one time?
Old Mar 29, 2008 | 08:26 AM
Madelinot's Avatar
There you go, that exactly how it starts. And I still use those jack stands to this day.
I'm replacing my engine with one that has forged rods and low-comp pistons. At the same time, I'll be adding a racing radiator, an oil cooler, injectors, another fuel pump and a fuel return system and a few other goodies. I intend to double the boost to 16-17psi.
I will likely do everything in May.
Old Mar 29, 2008 | 08:33 AM
whatacar's Avatar
GL Sounds great. So, you're obviously doing this to get better gas mileage
Old Mar 29, 2008 | 09:13 AM
RBull's Avatar
Rated M
Cool. I've highlighted the ones I've done and added some others.
ZTube
Air Filter
InCabin Microfilter
Spark plug change
Sway bar install
5/16 Plenum spacer
Shifter ****
BQuiet floor/trunk insulation
rear spring mount cut
grounding gear
braided stainless brake line install
Old Mar 30, 2008 | 08:09 PM
elrooko's Avatar
Just a question - when you changed your transmission fluid - how much did you put in? The manual says about 2.9 liters so I put in an even 3. It seemed like it could have taken more as the fluid wasn't coming out of the fillhole.
Is that how much you put in? I guess I'm just being paranoid.
Old Mar 30, 2008 | 08:12 PM
elrooko's Avatar
Maybe - I drive a lot on the Queensway.
Old Mar 31, 2008 | 08:04 PM
elrooko's Avatar
Have a look at this...the list keeps on growing
https://g35driver.com/forums/g35-sedan-v35-2003-06/183421-diy-video-series.html
Should at least let you know what the general steps are.
hdmark
Apr 29, 2019 04:31 PM
willdogs
Dec 8, 2015 11:32 AM
Jiggerjuice
Oct 5, 2015 02:33 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
