Canada Serving Canada.
TPMS for summer/winter wheels
Old May 20, 2008 | 08:23 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
^ good stuff.... sounds like a great dealer.
Old May 20, 2008 | 08:41 AM
GEE35FX's Avatar
+1, haven't heard of a Dealer doing it no charge. Too bad other Dealers don't follow their example.
Old Nov 27, 2008 | 08:09 PM
zx10r_646's Avatar
tpms re-learning pressure sensor ID with no special tools
Like most of you I have summer and winter wheels , each with tire pressure sensors. I have been searching for a DIY so I do not have to take my vehicle to the dealer every time I swap my wheels to register the tpms wheel sensors.
I have finally found a way to reset the tpms and register the pressure sensor IDs without any special tools (with the help of OBD3 Solutions and their BLOG - http://blog.obd3solutions.com/en/?p=20).
OBD3 found a way to reset and put the tpms into learning mode with a piece of wire and then register the tpms wheel sensor IDs using a wheel sensor activation tool. So if you have a tool to activate the wheel pressure sensors, you are all set to re-calibrate your wheels sensors yourself.
But if you are like me and do not want to spend $300-$500 to purchase a wheel sensor activation tool such as the KTI pst (www.ktipst.com), the service manual describes a method of registering the wheel sensor IDs without the use of an activation tool. All you have to do is alter the pressure in each tire, put the tpms into learning mode and drive the vehicle until all of the wheel pressure sensors are registered.
So last night I experimented to see if I could use 1) the ODB3 method to reset and put the tpms into learning mode with 2) the method described in the service manual to activate the wheel sensors without an activation tool.
It worked... after a little experimenting. The steps I used to register my winter wheel sensors were:
1) set different tire pressures in each wheel: RF to 34psi, LF to 31psi, LR to 28 psi and RR to 26psi;
2) start engine;
3) perform the OBD3 procedure to reset and put the tpms into learning mode - tpms warning light should be blinking;
4) drive vehicle around at speeds greater than 40kph until the tpms warning light stops blinking and turns off. Note a short time later, the tpms warning light should go on and stay on (since one or more of your wheels will be lower that 28psi);
5) disconnect the wire from the connector; and
6) reinflate the tire pressure to spec. and drive around until the tpms warning light turns off.
Larry
Old Nov 27, 2008 | 08:18 PM
InTgr8r's Avatar
^ wow.... excellent info Larry.
I know others will be eager to give it a try.
Old Nov 27, 2008 | 08:22 PM
RBull's Avatar
Rated M
^+1
Impressive info.
Old Nov 27, 2008 | 08:57 PM
zx10r_646's Avatar
Thanks guys
For those of you that don't want to use a wire to reset and put the tpms into learning mode, OTC sells a nissan tpms reset tool
http://otctpms.com/products/nissanreset.php
Larry
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
ResoG35Sedan
18 Inch
Nov 11, 2015 04:26 PM
TheKnite
Aug 14, 2015 07:59 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
