Canada Serving Canada.
Changing spark plugs
Old Jul 4, 2008 | 07:34 PM
  #46
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by nismog35driver
I had this thread up a few days ago about performance drop after about 20-30 mins drive
- slower throttle response
- shifts aren't as smooth (but not harsh)
- a lot of heat from underneath the car (coolant temp is fine)
One member suggested checking the spark plugs. I don't think I have changed them since 2003 and the car now have 64000km on them. Haven't tested them but I was thinking it wouldn't hurt to change them.
Really want to try Pulstar but heard that it doesn't last long and a lot have been using NGK iridium plugs.
Thank you
Have you ever cleaned the MAF?
Old Jul 4, 2008 | 07:36 PM
  #47
nismog35driver's Avatar
Originally Posted by RBull
I would question whether these are symptoms of bad plugs. It probably won't hurt to change them but I'm not confident it will fix what you're reporting.
Sounds like a 7 wire kit might fix at least 2 of the 3 issues if you don't have them now.
I have a 10 wire grounding gear coming in this week so I will give that a try, but not sure why the car is so hot all the time and don't know if there is a direct effect on the conditions I am getting.
Old Jul 4, 2008 | 07:38 PM
  #48
Got to check that too, not really sure if Nissan did it or not because that's where I get it serviced. But I will definitely look in to that.
Thank you
mtlruss
Dec 20, 2015 01:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
yassy
Aug 9, 2015 07:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
