Canada Serving Canada.
Throttle Body Cleaning
Old Jul 17, 2008 | 10:56 PM
cc101's Avatar
I trying search the forum but didn't find what I was looking for, so i hope i'm not asking questions which have already been answer many times.
I saw the DIY for cleaning your throttle body, but was not too sure about the whole "Accelerator Pedal Released Position Learning, Throttle Valve Closed Position Learning and Idle Air Volume Learning" thing at the end.
Are you really suppose to perform all those test? And how often should you clean it?
Thanks in advance guys.
Old Jul 18, 2008 | 07:53 AM
whatacar's Avatar
I had it done at 60 and 130km. Don't recall what the stealerships suggest. Check the manual for Infiniti recommendations.
Old Jul 18, 2008 | 10:51 AM
Smartidiot's Avatar
as far as i know, Infiniti owner manual did not mention anything about cleaning throttle body for G35....
Old Jul 18, 2008 | 12:32 PM
kingrukus's Avatar
BE VERY CAREFUL!!! Many of us have had the dreaded P0507 code after (high idle issue), and often the dealership will force you to get a new throttle body, as being the only fix around it.
When I cleaned my TB, I ran into a lot of issues with high idle. I finally was able to fiddle around, peform the accelerator/throttle/idle-air relearns, and finally got the idle back to normal. The local stealership didn't do any of these re-learns, and told me that geting a new TB was the only fix...
Old Jul 18, 2008 | 02:30 PM
Msedanman's Avatar
O.F. Administrator
An inspection will tell if it's carboned up or not, but as Sam says, every 50 to 60k should do it.
You should not have to do the throttle valve closed position and air volume learning just be sure to disconnect the battery b4 servicing the throttle body if you do it yourself.
C.
Old Nov 16, 2008 | 11:43 PM
maciejk's Avatar
I'm getting a rough idle i had my spark plugs,& filter changed recently, should I perform the Throttle body cleaning, is there a way to clean the throttle body without disconecting it? of if I disconnect the battery before i unplug the TB is there a need to do those learning procedures? will cleaning the TB make the bad idle go away?
Old Nov 16, 2008 | 11:57 PM
crashnburn's Avatar
yes dont do it unless u have to... i got an extra tb if u do decide to try it.... i did and had high idle and ses light got new tb and the did relearn atleast 40 times b4 it took
Old Nov 17, 2008 | 04:16 PM
maciejk's Avatar
heh in that case i better leave it alone, the rough idle bugs me a bit though the car shakes a little at the stop lights
Freeman186
Sep 6, 2023 10:07 AM
andy350gt
Sep 13, 2015 04:10 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Chadwick Arnold
Sep 9, 2015 02:59 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
