Canada Serving Canada.
Need Help - Hood hinges bending
Old Jul 27, 2008 | 08:33 AM
elrooko's Avatar
Looks like I have the dreaded hood hinge bending problem. I ordered new hinges but I was hoping someone had put them on before. Does anyone know if you can install them without removing the fenders? I can't find it in the FSM anywhere.
Old Jul 27, 2008 | 08:50 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I don't recall seeing anything on hinge install.
Just a wild guess, but what about with the plastic trays removed at the base of the windshield?
...fender removal would really suck.
Old Jul 27, 2008 | 08:59 AM
RBull's Avatar
Rated M
I guess you learn something new everyday. I hadn't read about weak hinges.
Maybe check out the replacements Chico had for sale if they still are.
Old Jul 27, 2008 | 09:00 AM
whatacar's Avatar
Pardon my ignorance if this totally useless but would a hood damper kit help?
https://g35driver.com/forums/showthr...highlight=hood
Old Jul 27, 2008 | 09:02 AM
GreenGoblin's Avatar
The goblin resurrection
sorry to give you the bad news but the fender needs to come off, I did mine about 2 months ago
whatacar's Avatar
Beat me by a few seconds eh Deane. I'd say something about great minds .... but who's believe me.
elrooko's Avatar
I have a hood damper kit and it actually makes the problem worse. I think the hood damper has bent the hinges over time. Apparently this is not an uncommon problem either with or without hood dampers. The problem is that the hinge itself is actually bent.
Old Jul 27, 2008 | 09:04 AM
elrooko's Avatar
Crap oh well...did the dealer do it for you under warranty? I'm long over that period, or did you bring it to a bodyshop?
Old Jul 27, 2008 | 09:11 AM
I did it myself
Old Jul 27, 2008 | 09:13 AM
elrooko's Avatar
I did it myself
You are my hero. No way I would have the ***** to remove a fender. Was it hard to get it off?
Old Jul 27, 2008 | 09:17 AM
Not hard just need to be patient and careful, but I used to work in a body shop for a few years
Old Aug 1, 2008 | 08:17 PM
elrooko's Avatar
So I got the hinges replaced at the dealer today. I'll post pics when I get a second. Man you should see the passenger side - it is bent a good 30 degrees. The body shop manager says they do 1 or 2 G's a day for hood hinges. The problem is that you can't lubricate the hinge where it is located and the passenger side always goes first. He gave me the hinge that was bent and man let me tell you, this thing was seized in place. I couldn't operate the hinge for the life of me and I'm a pretty big guy. He also said I was really lucky I was careful when I opened the hood and noticed that it was hitting the fender. He has seen all sorts of fenders come in that are knarled on the top from the owner just opening and closing the hood without checking.
Word from the wise - check you hood when you are opening it.
Old Aug 1, 2008 | 09:56 PM
shilohap's Avatar
Get a Krown rust control it will get anywhere you can't lubricate. Including the squeaky clutch pedal on some 6mt's. Just did mine.
Old Aug 2, 2008 | 07:46 AM
RBull's Avatar
Rated M
Thanks for the tip. I'll have to check mine out.
Old May 2, 2009 | 11:38 PM
chalupa's Avatar
i just had mine replaced under warranty. so there's no accessible point to lubricate them??? that's just ****ing retarded. looks like i'll have to go ***** out spraying wd-40...
