Squeeeeeeeeeellllll ing
For the last three days, when I start the G it squeals. If I give her a little gas the squeal increases with the rev's. It only lasts for a few seconds and then all is well. I had all my belts replaced 6 000k ago. My driveway is fairly steep, if that could be relevant. This only happens upon the first start up of the day.
I've got 137 000 km. on my beauty. Waterpump? All thoughts and suggestions welcome.
Originally Posted by snavematt
belts are loose, just tighen them up
BTW. Is this a DIY? or should I take it to a mechanic?
Originally Posted by 35bills
Yep...belts are loose. Mine did the same after I had them replaced. Vic just re-tightned them and no problems since.
It's a long drive to Vic for me.
No need to loose any hair over it
Loose hair, can't find any to loose. I'd be squealing higher than the G.Thanks for the fix guys.
My bet is on belt tension also Sam.
Oh, and Ian can solve the hair problem, if you don't mind red or auburn.
LOL^^^^^^^^^, when would this happen,,,,,,,,,,
Should I take the G into a shop to have the belts tightened? Mine's been getting worse since I had my new VQ installed, new belts and all... or is it something I can do myself?
The job isn't tough but you do need to know where to look (from underneath up to the tensioners) and how much to tighten them.
.....and no you shouldn't need new belts, but again that should be evident by inspection.
Colin.
Yeah I figured they dealer could do it for me since they installed the new VQ recently. My issue is that they're like 100 miles away. Wonder if another dealer would do it for free since it was a warranty repair.
-B
-B
