Canada Serving Canada.
Grinding into 3rd?
Old May 29, 2004 | 12:01 AM
TripleQ's Avatar
Grinding into 3rd?
I'm pretty consistently grinding the gears shifting into third these days, usually happens more often when just starting out before the car has warmed up.
Maybe I'm just too quick on the clutch but I don't think I've changed my driving habits that much and it never used to do this.. the clutch pedal is all the way in and it just feels like the gears haven't disengaged yet.. anyone else having a similar problem?
Old May 29, 2004 | 11:54 AM
BobbyD's Avatar
Re: Grinding into 3rd?
I have this problem with 2nd when the car is cold, I need to shift very slowly to avoid it. After the car is up to operating temps its much better, but not 100% perfect. All other gears are fine except sometimes I will slighlty grind 3rd if I'm a little to quick with the clutch. If you can reproduce the grind at a dealer the only fix is to replace your tranny.
2003 G35 Sedan 6MT
14.13 @ 99.55 (stock)
Old May 31, 2004 | 12:07 AM
WolfsterX's Avatar
I heard the rogue engineering short shifter is amazing. I heard it is a bit of a shorter shift and every shift makes it a lot smoother and no more notchyness and uncertainty between shifts. Yes we all know that NOTCHINESS still pain in the butt. If you guys/gurls ever driven BMW or HONDA cars with stick, it'll be smoother as it is. I gotta find a price on the Rogue short shifter and get them installed.
Old May 31, 2004 | 04:04 AM
Msedanman's Avatar
O.F. Administrator
Sounds to me like your tranny is starting to have the same issues as many 6M/T owners to date. Their syncro problems have made a new tranny necessary, and some are on their 2nd and 3rd box.
Time for a trip to Guelph Infiniti.
G/L
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old May 31, 2004 | 12:20 PM
WolfsterX's Avatar
gsedanman,
that's where i bought my car from Guelph Infiniti as well. I'm gonna write him a letter saying that Shift is causing a problem and it needs to be replace it!
Old May 31, 2004 | 12:51 PM
Msedanman's Avatar
O.F. Administrator
WolfsterX, Just call them and make an appointment. They'll want to see your ride to do an evaluation.
G/L with the fix and see you at the next meet.
GSM (Colin)
Old May 31, 2004 | 02:42 PM
TripleQ's Avatar
Crap.. that's not what I wanted to hear, GSM.. thanks for the tip though, I'll give Guelph a call.
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alinero718
Sep 27, 2015 09:35 PM
Hawk196
Sep 10, 2015 10:37 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
