Canada Serving Canada.
Springs or Coilovers??? Please help..
Old Dec 1, 2008 | 01:11 AM
kos52's Avatar
I recently purchased a 2006 G35 coupe and I have been thinking about lowering the vehicle. I spoke to my mechanic and he suggested I purchase springs instead of coilovers as it would be a waste of money if I drive the car in the winter.. I am hoping someone can provide me with some additional info in letting me know what are the best springs for the street?? To be honest I am a bit confused and I am hoping for some direction.. Any comments?
Old Dec 1, 2008 | 01:31 AM
intense660's Avatar
if you get springs, you might wanna think about getting shocks because the OEM ones arent going to support springs for more than a year. But as your mechanic says: if you drive it year around you would probably avoid coilovers...why?
1) most aftermarket coilovers are only rated around minus 4 degrees celcius, they won't be recommend for harsh canadian winters.
2) the salt used for roads has the nack for ceasing coilovers (meaning if salt clutters your coilover threads, you cant adjust them anymore)
BUT
if you want to, you can run your coilovers through winter, Im sure many people have done this before (including me, not on the G though). To get through the winter you must make sure you use lithium grease to keep your threads lubricated on a regular basis. And you have to probably wash every week to ensure the salt doesnt enter the coilover.
Old Dec 3, 2008 | 01:24 PM
kos52's Avatar
Thanks Intense for the reply... Since I am new to G35 forum was this displayed in the canada forum site?
Old Dec 3, 2008 | 02:54 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Yes....
did you intend posting here or in the tech section????
When you hit new thread at the top;
It will post in the section where you are currently browsing.
If you want to post to a specific section, you need to navigate to it first.
Old Dec 3, 2008 | 03:34 PM
gcoupe_toronto's Avatar
+1 thats what i did also on my previous car
kos52 - I am in the same dilemma however I think I will end up getting Tein Basics (Had no complaints when I had them on my old car)
Plus the ease of being able to lower and raise it.
Question for the experienced - If you get for example Tein basics lower it + camber kit and then decide to raise it for the winter what happens with the camber? Would you need to get/adjust camber again when summer comes around?
Old Dec 3, 2008 | 03:52 PM
InTgr8r's Avatar
It will change more than just camber.
Old Dec 3, 2008 | 11:49 PM
kos52's Avatar
So then for an easy 1 inch drop would the 350Z springs be the best fit since I will leave the OEM shocks?
Old Dec 4, 2008 | 08:58 AM
RBull's Avatar
Rated M
350Z springs will lower the front 3/8 - 1/2" and nothing in the rear. No easy 1" drop.
Old Dec 4, 2008 | 04:35 PM
kos52's Avatar
So what about Eibach pro kit springs.. Do you guys no anyone who is running these springs with original shocks?
Old Dec 4, 2008 | 04:55 PM
netcbc's Avatar
You can also get coil covers which I have done with my basics
Old Dec 4, 2008 | 05:03 PM
ttrank's Avatar
Grocery getter
Many have done this. You won't get the best performance and your oem struts will wear out faster but it can be done.
Old Dec 5, 2008 | 06:24 PM
KesterG's Avatar
have been through H&R (with OEM shocks), Eibach, Tein S-tech, and H-tech (with Tokico shocks)
I prefer my Tein basic right now...
Old Dec 6, 2008 | 12:07 PM
rzua5's Avatar
If you are planning to OEM comfort with height adjustablility, then Tein basic will be the best option.
Old Dec 6, 2008 | 03:30 PM
kingrukus's Avatar
I would go with an aftermarket spring/strut setup for durability against salt/snow/etc. I have seen various coilovers die quite often after 1 hard winter, and need to be rebuilt. If we lived a so-cal type environment or if you car isn't winter driven , then coilovers would definitely be my first pick.
Old Dec 7, 2008 | 05:03 PM
kos52's Avatar
Thanks guys for the all the help..
